Question about Sony Playstation 3 (PS3) Console
When I push the sensor to turn the system on and the red light turns green then yellow and then it beeps five rapid times. the light goes back to red but now it's blinking. the system will not turn, what's wrong
  • 65 Answers
This is known as the YLOD.
Here is someone on eBay that does the repair. I have had a few fixed here.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380166005639&ssPageName=STRK:MESELX:IT
Posted on Nov 14, 2009
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
My ps3 will not power up
here is step by step trouble shooting
1) attempt to turn on the ps3
+you will see one of 4 things a green yellow red light
+flashing red light
+green light
+no lights
2) if you see a green yellow red light call sony your system will need service
3) if you see a red flashing light also call sony needs service
4) if the light is green turn off the system and one the light is back to red press and hold the power button for a series of 2 beeps (do not forget the one when you first push the button down) then let go (it might be a video issue)
5) if you still see no video and a green light check the cable you are using and try again on a different tv
6) if you see no power light call sony it needs service
these are genuine trouble shooting steps from sony technical support if you do have to call them be prepared to follow the same steps that lead up to service. thank you
Oct 30, 2011 | Sony Playstation 3 (PS3) Console
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Turns off straight away
system hard drive is corupt needs to get repaired. $$$$$
Aug 09, 2009 | Sony Playstation 3 (PS3) Console
Lexmark c530dn red light on
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Mar 12, 2009 | Lexmark C530dn Laser Printer
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
