Question about RCA HD52W59 HDTV Projection Television
Rca tv, sound but no picture
I have a widescreen RCA tv, when i turned it on tonight it popped and had no picture, only sound. i turned it back off for a minute. tried again, unplugged the power cord from back of tv. waited a minute and plugged back in. also turned off power strip for a minute, then turned back on. still no picture.
techman
  • 3130 Answers
SOURCE: Please Help!
A chirping sound from a TV set is the switch mode power supply trying to start up, but gets shut down because of a major short inside the set or in one of the circuits.. Most likly in this set, the horizontal output transistor is shorted because of a defective flyback transformer. Thats whats the common problem is with this set. A repair like this, if this is the only parts that are bad, will run you about 300 to 400 bucks or so. In some cases, not many but a few times, I have seen poor solder connections on L401 cause the horizontal output transistor to go bad. There are no user replacable parts inside this set, so please play it safe and seek out a pro to assist you in this repair. Good luck PS Please do not forget to rate this thread.
Posted on Dec 11, 2006
SOURCE: RCA 50" widescreen model M50WH74S Quit working
the deflection board put set into shut down,should be under warranty for service.
Posted on Sep 15, 2007
  • 16 Answers
SOURCE: TV will not power up
LoL!!! I don't know why but all RCA's have Flyback Transformer problems! I have one to here is the part number 259296 if you look around you can buy it for about 15.00 if you know how to solder you can do it your self and save big time! Hey I'm doing it! I don't see paying $500.00 to fix it you could buy a new one. And they are just ripping people off because the parts aren't really that high to fix the flashing light problem. And the part is never on back order so your getting screwed they are probably wanting you to finally say just throw it away. And than they'll fix it for $15.00 and sell it for $600.00 Anyways for the people that are having the same problem go here to buy the Flyback Transformer for the D52W20 http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=c5d90cbb7ae2d4c1449ea48542eef46a&keywords=259296&x=4&y=14
Also here is another website if you have access to junk TV's and want to know what other RCA Flyback Transformer will work. The price on this site is higher for there's though
http://www.partstore.com/Part/Thomson/RCA/D52W20/Thomson/RCA/259296/New.aspx
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/benjamin_494963e790f97efb
Posted on Dec 10, 2007
SOURCE: rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Posted on Jan 25, 2008
SOURCE: rca scenium turns off and on
I wish I had the idea to install a cooling fan, a local repair shop fixed mine by replacing a power supply component, cost $575 including sales tax. I suspect that a cooling fan would increase the life of the power supply, I will install one!
Posted on Dec 04, 2008
Rca scenium hd50lpw166yx12 power blinks five
I have the same problem -- now it made a loud pop and just went completely black and only the sound will turn back on,... have you received any answers to this?
May 14, 2010 | RCA HD52W66 Projection Television
Rca dlp hdtv widescreen - terrrible noise/flashing light
if its a dlp its most likely the color wheel that is causing the problem. Post your model number and i will assist you.Please respond to this same post.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Tv has sound but no picture
my rca hd model hd50lpw164 has no picture. some sound and a electrical popping noise.
supect the lamp is out.
where can i obtain new lamp and whats the cost.?
david
Nov 20, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
No Picture
where can i buy Deflection board for RCA D52W20
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Rca tv
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA HD52W59 HDTV Projection Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
