Question about Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
I own a Maytag MGR5754QDQ gas range. In June of this year my area experienced a power outage. Upon re-connection of the power by the power company the power was turned on and off several times until finally the power was restored. Ever since then my range shows "CAL" on the screen. The oven does not work at all, but the burners do work. PLEASE HELP!! I have contacted Maytag and no one can seem to find this code or tell me how to fix it. Josh
  • Joshua Cooper Nov 15, 2009
    Vladimir77, you are a genius!!! You are the only person who's been able to tell me what is wrong with this thing. Soft reset did not work, so I will be replacing the control, Thank you!!!
  • 375 Answers
"CAL" means calibration is out of range. If "Hard reset" - unplugging the oven and plugging it back in does not help - replace control. You can read about this error here. This document is about the electric ranges, but the codes and all tests.and procedures are the same. Try entering the quick test mode (page 4) and testing the range. Entering quick test mode also should do "soft reset". Part number for your control board is 74009153.
Good luck.
Posted on Nov 14, 2009
I cannot relight my stove after a power outage? I have a gemini maytag
Could you please describe the problem you are having a little better?
Is it the stove, the top burners or everything?
Nov 30, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
WMGR 5750BDW replaced burner. now smell gas what do i do ?
check all connections where gas flows mix soap and water and rub it around the connections if this doesn't work call your gas company or call a professional
Jul 21, 2012 | Maytag MGR5750 Gas Kitchen Range
After a short power outage, my Maytag Gemini Gas Range upper oven came back on (it was on at the time the power outage happened) and I cannot shut it off from the panel. I have tried to reset the oven to...
Hello, Thank You for using FixYa. I will be helping you today.After looking at the wiring diagram for this unit it looks like the only thing that can be happening is the relay on the control/clock is fused closed thus energizing the heating element. Bad thing is this part is about $360.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MER6769 Gemini Electric Kitchen...
THE PROBLEM OCCUR AFTER A POWER OUTAGE .I TRY LOOKING AT IT BUT IT DID"ENT COME ON THE OVEN WOULD NOT HEAT UP
Try to open the back cover of the oven and check for the fuse which is located in the power supply section. If there is no power, it is caused by a busted fuse.
Nov 29, 2010 | Maytag MGR4452ADW / MGR4452ADQ /...
How to use kenmore gas range during power outage
just use a match to light top burners, the oven will not work or pass gas if you have a electronic ignition range
Feb 06, 2010 | Kitchen Ranges
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Jun 13, 2008 | Maytag MGR5751AD Gas Kitchen Range
Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Feb 20, 2007 | Maytag MGR5751AD Gas Kitchen Range
Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range Logo
81 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
