I have an old Sanyoradiogram system,,dc-570xn series,and would like to know how to replace the belt drive. The turntable won't lift off. Can you please tell me how to remove the turntable, so I can replace the belt. Thank you.
  • 6771 Answers
SOURCE: Hi, I have a JVC
remove rubber pladder and use a flat blade screwdriver to remove the clip "carefull it may take off on you" next slide off the pladder, remove the old belt. Now! take the new belt put it around the inner part of the pladder, next put the pladder partly back on the center spindle and rotate until one hole lines up with the motor, take a hook and slip it under belt now carefully stretch over to the motor put on and push pladder into place and rotate it by hand clockwise to make sure it is in place, next reseat rubber pladder back on and power up to make sure it is working before replace the clip.
Posted on Feb 14, 2011
Testimonial: "very helpful, great, just what I needed. thanks"
  • 319 Answers
SOURCE: fisher turntable mt 6410 removal
Look at spindle bearing in center of t-table. There is probably a small ring lock there holding the table. Use a pick or small screw driver to carefully remove this ring.
Posted on May 07, 2008
djproaudio
  • 515 Answers
SOURCE: drive belt on Sony turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
  • 104 Answers
SOURCE: How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Posted on Feb 11, 2009
  • 104 Answers
SOURCE: turntable
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Posted on Feb 12, 2009
Why did it stop revolving?
The driving element, be it belt or rubber puck, may have failed. It's not an unusual failure in a turntable that is several years old and rarely used.
Jan 08, 2016 | Audio Players & Recorders
Need Instructions to replace belt on panasonic SL-5N Turntable
To replace a turntable drive belt.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Apr 11, 2013 | Audio Players & Recorders
NEED A BELT FOR MY DC SERVO AUTOMATIC TURNTABLE SYSTEMS SL-B210
You have to check an electronic store. If it does not have old one get a piece of string and measure around where the belt goes so you can know how big it is. Or you would have to order online, russell electronics sells all type of electronic belts you would have to search for a radioshack or another electronic store in your area.
Aug 20, 2009 | Technics SL-1210 Turntable
Direct drive turntable will not rotate
If it does not rotate, more than likely the belt has either come off, or is broken. Lift up the turntable platter, and you'll see what the issue could be. The platter just lifts right up.
- OPTiC
Dec 27, 2008 | Sony PS-LX250H Turntable
Belt replacement
above is a generic video that applies to almost all turntables including yours that will show how to install the belt an a few other things.
Nov 08, 2008 | Aiwa PX-E860 Turntable
JVC turntable LA10
The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
Hope that helps.
Mar 16, 2008 | Audio Players & Recorders
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Feb 17, 2008 | Technics SL-1210 Turntable
Turntable drive belt replacement
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Nov 27, 2007 | GPX S7799 Shelf System
120 people viewed this question
 Grubhead
Grubhead
