Question about Zodiac Pacer Pool Cleaner
Our Zodiac Barracuda pool cleaner isn't working
Our barracuda isn't sucking at all, but the pipes connected to it are. the pump and all runs fine, just when we connect the pipes, it just doesn't go.
  • 366 Answers
You may have a bad diaphragm inside the unit. Unthread the nut between the "wagon wheel" and the lower unit and remove it, push down on the white tube until it comes out of the bottom of the barracuda. Inspect the rubber diaphragm for debris and deformations. If the diaphragm has a large gap inside, it won't work properly. It needs to have only a small uniform gap, they can sometimes even look completely closed when they are new. Replacing the diaphragm will most likely make the unit run like new again.
Posted on Nov 14, 2009
Pump quits sucking water when barracuda plugged in
you must prime the hose with water before connecting the cleaner, hose might also have holes in it, look for leaks
Aug 05, 2013 | Zodiac Baracuda G3 Automatic In Ground...
My barracuda g4 pool vacuum is running reverse only
That's how they run, they basically just follow their hose!
Apr 04, 2013 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Moving intermittently
Check for the following problems with these pool cleaners. Check diaphragm for blockage or damage. Adjust a worn diaphragm by loosening cassette swivel, gently pushing down on inner pipe, and retightening cassette swivel. You will probably need to replace the diaphragm if that doesn't work.
Apr 02, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda Pacer comes right up the side and above waterline then sucks so much air, pump has to be reprimed. Really annoying
You just need to slow the cleaner down and dirvert some suction away from it. It should never really come anymore than 1/3 the way up the wall.
Mar 29, 2010 | Zodiac Pacer Pool Cleaner
It seems as if the sucking power of the pump is too strong because one or two pipes become sucked quite flat and then the barracuda doesn't work properly. Why is this?
Replacing the flattening hoses will resolve the problem.You might want to check the suction and keep it at the lowest amount necessary to run cleaner.
Mar 17, 2010 | Zodiac Baracuda Zippy Pool Cleaner
My Barracuda was working the other day before the
If your moving water it sounds like you have a suction valve that needs to be reset to the cleaner. If your main drain is plugged off as it should be with a suction cleaner, the pump will strain. Or it may be a plugged line. Check this by putting a small kitchen sponge it the skimmer and see if it gets pulled through to the pump basket. If it does not get there you have a plug.
Oct 04, 2009 | Zodiac Pacer Pool Cleaner
Barracuda not bouncing or moving to clean pool
Check suction at cleaner. Could be broken hose, bad or dirty impeller, incorrectly set valves, dirty filter, clogged line and probably a bunch more things.
May 29, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Pacer Pool Cleaner Logo
1,726 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
