Question about Panasonic Kitchen Appliances - Others
Panasonic SD-250 not mixing. Pan was submerged in water.
I don't want to repeat myself but I can't find the problem I submitted hours ago, so I've created an account and logged in to try again:
I have a Panasonic SD-250 which is no longer mixing. I normally use the timer and I use bread mixes so I'm not sure of the process, but the resulting loaves are flat, wet and sticky. I did some testing today and I can rotate the paddle with slight resistance in 2 places on a 360 degree turn. It appears it's tried to start mixing - there's mix spattered on the sides of the pan and even inside the lid, but it never gets past a wet mix. It's been working beautifully but a week or so ago it was washed up twice (ie. the pan was submerged in water) without me knowing about it. Would that be the cause of the problem and is there anything I can do to fix it?
Many thanks,
LT in Brisbane
  • LTBrisbane Nov 17, 2009
    Hi Hank,
    Thanks so much for your help. I don't have a window but it works with the lid open and on a Rapid Bake setting the paddle worked beautifully. I even created a little bit of resistance with my finger to see if it would stop but it was fine, so I tried another mix on Rapid Bake. It didn't spatter any mix at all and I was able to watch it through the mixing process (I'm learning heaps!). I had high hopes but same result I'm afraid. Tried another mix and new yeast but got the same flat, wet, sticky result.
    LTBrisbane
  • 433 Answers
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Posted on Nov 16, 2009
Will not heat or brew to heat
Take 1 Cup of white Vinegar and fill the decanter the rest of the way with water put the mixed water and vinegar in and let it try to start to heat , if the heating coil is blocked totally up with scale from the water you must let it sit for a few hours,maybe overnight.If you have any flow when it starts to heat let it drip a little bit then turn off the heat and let it sit for 15 to 20 minute the put the heat back on and you should get back your normal flow.If not you must repeat the steps and keep doing it until it work correctly.By the way make sure to put a clean coffee filter in the basket if you have one,you don't want to keep sending the mix of water and vinegar that went though the machine.The scale that comes out will get caught in the clean coffee filter. Please E-mail me and I will try and help you. johndem1x@verizon.net
May 02, 2012 | Coffee Makers & Espresso Machines
I have through bolts stuck in rear spindle (knuckle). I have them removed from the car. I have been heating and spraying with WD 40. (day one) I let them take a 2 day bath submerged in PB Blaster, then...
seems like a considerable effort when the wreckers/junk yards are full of good units
may be the bolts are part of the rubber mouldings
have you tried a hydraulic press to push them out
Jul 15, 2017 | 2000 Dodge Neon
I lost my instructions for the recipes and i don't know how to make the cake mixes
I have the recipe for yellow cake from the handbook:
preheat over for 15 minutes and spray pans with cooking spray
1. pour contents of yellow cake mix into bowl and stir to break up any lumps. 2. add 1.5 teaspoons of water and stir to form batter 3. pour batter into baking pan and spread evenly. 4. place pan in baking slot of oven and use pusher end of pan tool to push it into baking chamber. Do not use your hands. 5. bake cake for 12 minutes. 6. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 7. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. Transfer cooled cake to a plate, turning over so bottom faces up.
frosting 1. pour contents of frosting mix into bowl. 2. add 1/2 teaspoon of water and stir until smooth. For thinner frosting, stir in a few extra drops of water. 3. spread frosting over cooled cake.
Sugar Cookies
1. pour contents of sugar cookie mix into bowl and stir to break up any lumps. 2. add 3/4 taespoon of water and stir to form dough. 3. sprinkle your hands with flour and shape dough into 6 small balls. 4. flatten 3 cookie balls and place in baking pan. 5. place pan into oven and use pusher end of pan tool to push into oven. Make sure both metal doors are closed. 6. cook for 10 minutes. 7. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 8. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. 9 repeat steps 4-8 to make remaining 3 cookies.
those were the basic recipes in the handbook. Hope that helps
Jul 25, 2011 | Hasbro "easy Bake Oven and Snack Center"...
The dough doesn't seem to be mixed properly. I can see the yeast particles, the dough is tough and not-elastic. Doesn't seem to have risen. When I put it in a warm place to rise, it seems to rise a...
Hi, It could be that the paddle is sticking or the belt is slipping. This would cause the ingredients not to be mixed properly. Take the empty pan and paddle out of the machine and see if you can spin it freely by hand. It shouldn't stick. If it does stick then the sealed bearing is frozen and a new bread pan is needed. If everytrhing is fine, then check the belts. Belts and motor are located in base of the machine. Unplug machine before working on the belts. Hank
Nov 11, 2010 | Panasonic SD-YD250 Bread Maker
Gear box oil mixing with water
Usually most gear boxes have a rubber vent tube somwhere, I think you must be submerging this tube while using or washing the bike.
May 04, 2010 | 2003 Suzuki RM 250
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
DROPPED CANON POWERSHOT SX10 IS IN SALT WATER (NOT SUBMERGED). WILL NOT WORK. ALLOWED TO DRY OUT SEVERAL HOURS, INSERTED SD CARD AND BATTERIES. DOES NOT TURN ON.
First of all, it would take days, not hours to dry out. Turning it on too soon can fry the circuits. But worse than that, salt water is extremely bad for a camera. Most places won't even repair it.
Sep 25, 2009 | Cameras
The pan is stuck in my Sunbeam bread machine
I just had the same problem. What the manual either does not tell you or hides quite well is that you have to TWIST the pan before lifting it out. I don't know why this was listed under the Panasonic bread machine when it clearly refers to the Sunbeam bread machine.
Feb 05, 2009 | Panasonic SD-YD250 Bread Maker
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Sansa c250 frozen
try to dry it using a brush and medical alcohol and a hair dryer and check if it would give u result
Oct 09, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Kitchen Appliances - Others Logo
458 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
