Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
Usb2.0 hdd external hard disk-unrecognizable device
I have a usb2.0 hdd external hard disk, all computers stopped recognizing it. can i still retrieve data from it another way?
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 08, 2009
Western digital pasport cant be recognised in windows except in device manager. pc inspector shows this error code.
Error no.1117
drv:131 LBA:0Blocks:1
    Champion:
  • 206 Answers
You can try retrieve data using some windows live OS.
boot it from a disk, and then you should have total commander, or something similar.
If that doesn't work, I'm afraid that all of our data might have been lost for good
Posted on Nov 14, 2009
How do I recover the files on a broken hard drive?
Depending on why the drive failed, it may not be possible unless you want to spend some serious money and send the drive into a company that specializes in data recovery.
Jul 13, 2015 | Hard Computers & Internet
I CAN NOT RETRIEVE DATA MY COMPUTER WILL NOT
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this hard drive data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 26, 2011 | Iomega 1TB Prestige External USB 2.0 Hard...
Hello. I have a laptop hp, but i found out that the hdd is toshiba mk6465GSX.. Today i was working in my office and it suddenly crashes and the board didn't see it for booting..in fact the hdd is...
You can try placing it into an external hard drive caddy (your internal plugs into it)
The device will plug in usb 2.0 and recognize as an external drive.
If the drive is unrecognizable, than unfortunately it has physically failed and costs to recovery data are very high.
Always have 2 forms of backup for all data.
May 23, 2011 | Xante Internal IDE Disk Drive Hard Drive
Hitachi SimpleDrive Mini-red wine USB 2.0 Portable Drive - 250GB SDM/250RW This external drive is not recognized by my pc- i'm running windows XP but have tried it on a Vista too, and also beeps once...
If you have tried it on two PCs with the same result, the hard drive is most likely defective. If so, the computer may recognize it being plugged in with a beep but will not recognize it at all as an accessible device.
One thing you can check is if the hard drive was never initialized, meaning that there is empty space but the empty space isn't configured for the operating system to recognize and use. To do this:
- Go to "Start" and "Run" and type in "diskmgmt.msc" and hit "Enter".
- A list will pop-up listing all hard drives on computer. Each row is a physical hard drive.
- The main hard drive for your computer should be listed as "Disk 0" and the local disk in it should be "C:".
- Assuming you have no other hard drive besides the external, the next row should be "Disk 1" and say "Unallocated", which means the hard drive was never initialized. In this case, right-click on it and select "Format". Click next through everything and the external HDD will be formatted so that Windows can recognize it.
- MAKE SURE NOT TO FORMAT LOCAL DISK C:!
- After that, the external HDD should be recognized fine and pull up in "My Computer".
Otherwise, if no other hard drive is listed, the external HDD is most likely defective and you will need to purchase a new one.
Feb 28, 2011 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
Windows cannot recognize my western digital external hard drive. I am getting an error msg: "Windows cannot recognize this device". I need to retrieve my files! Help!
The device has suffered a major failure. If you're lucky it's in the electronics of the case so take it apart, extract the hard disk inside, put it in another external case (or directly inside a desktop) and access it this way. If even then the disk isn't recognized then the hard disk itself has died and all the data on it is lost.
Aug 23, 2010 | Western Digital External USB 2.0 80 GB...
Computer wont recognize the harddrive
It might be the case that the External HDD is not formatted correctly with proper file format. If you are using Windows XP right click on My Computer icon on desktop -> Properties. This will open Computer Management, there click on Disk Management and search for you device, click on the device and format it correctly and it might solve your problem. For other OS version search for Disk Management and then format the External HDD correctly.
Give your feedback here.
If this solve your issue plz rank me.
Jun 19, 2010 | SimpleTech Signature Mini 160GB External...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Jun 09, 2009 | Western Digital 500GB My Book World...
WD1000VE external hard drive not recognized
If possible check it out on another computer.
This will then establish one or the other which is misbehaving.
Then come back
Feb 11, 2008 | Western Digital (WD1000VE) 100 GB Hard...
LaCie PC
Try to put hdd in ( for whillem 74) another EXTERNAL!Or just buy new external then put hdd in new external.There is no way to repair it i think!!!
For Fiddler 51 Try hdd in external if it wont acept also then hdd is damanged!
Dec 04, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
815 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
