Question about Toshiba REGZA 47HL167 TV
How do i remove the stand so i can wall mount the set toshiba regza 46xv645u
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Posted on May 17, 2009
  • 5 Answers
SOURCE: How does one remove the Toshiba TV stand.
ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
Posted on Mar 10, 2010
Testimonial: "Thanks for that - will try it!"
  • 5 Answers
SOURCE: I have a Toshiba Regza 42HL67US
First you should lay the unit face down on a blanket or the like, being careful NOT to damage the screen. I don't have one in front of me right now but if memory serves well, there is a plastic cover on the back side of the base that you can pop off giving you access to the base mounting screws. Remove the 4 screws and viola, the base should slide off.
Posted on Jul 21, 2010
budmrtn
  • 11361 Answers
SOURCE: what size bolt do i
Metric M5 or M6 from HD or LOWES for about 35 cents each.
Get different length to try.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 14, 2010
  • 30 Answers
SOURCE: how do I install the pedestal stand for the
the stand just slots into the bottom of the tv and you just tighten it with four bolts provided.
Posted on Nov 29, 2010
Toshiba regza 46xv645u won't turn on and clicks
the clicks is it trying to come on an is crowbarred off
an error condition in the power
many just over heat an the large capacitors in it short out
it will take isolation of circuits to find the exact module . likely the power module . that you might find on ebay.
Jul 25, 2014 | Toshiba 46"" regza 46xv645u 1080p 120hz...
Remove stand on Toshiba TV
To disassemble it, you have to see some illustrations. If you wish to get more details about how to disassemble Toshiba TV, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Disassemble procedure to many TVs are given in detail, with illustrations.
Jun 13, 2013 | Toshiba REGZA 47HL167 TV
I need to know how to remove the bottom from my Toshiba Regza TV so that I can put it on a wall mount.
What you need to do is with the model number GOOGLE to see if you can find a service manual or even a owners manual.
Most of these sets you carefully lay the set on a padded surface face down and look at back-----should be four or more recessed holes with bolts that secure the base to the back/bottom of the set.
Most of these also you have to remove that base to get the back off which is a hint---usually no small screws but bolts.
Hope this helps you
Mar 17, 2012 | Televison & Video
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Cant get my stand of my tv to mount it on the wall can you help?
If you turn the set over you will see a set of screws attached to the bottom of the stand (inside hollow area). There also two screws I believe on the back of the unit near the stand area that need to come out. The stand should come off now. But do you really want to mount it on the wall?
Oh well,
Hope this helps
Skyassoc
Jun 22, 2009 | Toshiba REGZA 47HL167 TV
I need to remove my flat screen footing so i can mount it to the wall
on the back of the set near the stand there is 2 - 4 screws just unscrew them, you will need to giv the pedistul a good tug but it will come of :D
Mar 10, 2009 | Toshiba REGZA 52RV530U LCD TV
Taking stand off toshiba regza tv
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Toshiba REGZA 47HL167 TV Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
