Question about Singer 8280 Mechanical Sewing Machine
My machine is jammed and trying to turn the wheel manually is very difficult
  • 108 Answers
I was able to find one at www.ifixmchines.com
Posted on Feb 15, 2010
My singer simple; the wheel is difficult to turn, the needle wont go up and down, the material wont feed
Sounds like you have a thread jam( bird's nest) inside your bobbin housing. Take the face plate off, remove the bobbin, and take the housing apart if you have to...then start all over with winding new thread on the bobbin and re threading the machine before you try sewing. Hope this helps!
Dec 03, 2016 | Singer Sewing Machines
Why doesn't it sew?
Check to see if the bobbin case is in correctly. Jamming occurs when something isn't in machine properly. Try taking out the needle & manually turning the hand wheel slowly. It could be just a bent needle too.
Mar 13, 2016 | Baby Lock Sewing Machines
Motor runs machine jams, wheel hard to turn
Unless you are a qualified service technician, take it to a technician for repair. Trying something yourself may cause more harm.
Feb 24, 2015 | Sewing Machines
Fly wheel won't turn
If all you get is a "whirring" sound when you try to run the machine, the belt most likely has slipped off the pully. You need take off the rear cover to get at the belt. Get a service manual that shows the bottom and rear Torx screws that have to be removed if you plan on fixing it yourself. If the hand wheel won't turn manually (or is difficult to turn), take it to a professional.
Mar 18, 2014 | Husqvarna Viking 1
My Silver Crest 8750 sewing machine has jammed, i cant even turn the wheel, i have cleaned it out and lubricated like suggested in the manual, but still not working..... i have only used it about 10times....
did you try turning the machine off & on again to see if that clears it?
is the machine new or used? if it is used, was it bought used?
has the machine ever been serviced?
Apr 09, 2012 | Sewing Machines
Needle doesn't move, the balance wheel is very hard to turn
Sounds like it is jammed with thread or fabic. Totally rethread your machine and clean out your bobbin area. Then try turning your wheel towards you. If, you do not have your manual to check, go to www.sewingmanuals.com and download one for $10. If that doesn't do it, all you can do is take it in for service.
Sep 19, 2010 | Janome L-344 Mechanical Sewing Machine
Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Jun 10, 2009 | Singer 8280 Mechanical Sewing Machine
Machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
May 01, 2008 | Necchi 3101 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
143 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
