Question about Alto 302000414 Attix 8 AS/E Canister Wet/Dry Vacuum
I have a ceiling light with a holgen bulb that I cannot figure out how to change. The fixture has an outer ring against the ceiling and an inner ring that has the light. The inner ring tilts. I have not idea how to get into it to change the light!
  • 1,056 Answers
From what I know you are suppose to change the whole thing.
Posted on Nov 14, 2009
The bag will not stay attached it comes off the rubber nozzle and dirt gets everywhere my old oreck had a much better design with the velcro closure.i am very dissapointed.
Please make sure that the plastic pieces that holds the outer/inner bags on the vacuum are attached properly. Push the outer (permanent) bag down against the vacuum. It will go over a black lip. Put first piece of the bag dock on..make sure it is behind that lip also. When you reattach the second piece to the dock, this will tighten the docking system. It will keep the outer bag on and keep the inner (disposable) bag in place so that it is catching the dirt...not the outer bag.
Sep 23, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I have a euro model s3325 and when i turn on the power switch it says its steam ready but will not heat up
I think it may be from the same issue stated above--the thermal fuse blew. I have the exact same problem. This is what someone posted earlier:
There's a thermal fuse inside. If it gets too hot, the fuse will blow and the thing won't turn on.
It has a 216 C temp limit. You can find thermal fuses at radio shack for less than 5$. If you're adventurous enough, you can find the fuse in line of a white wire under a fiberglass outer and heat shrink inner shielding screwed against the bottom of the tank.
Now to figure out how to get to it!!!
Aug 12, 2011 | Euro-Pro S3325 Handheld Steam Vacuum
I have a victorian casablanca fan serial # JU13396 - 20041. A couple days ago the light fixture assembly fell off the fan and crashed to the floor. Evidently there is a type of clip that fits under the...
this clips are common for most of the ceiling fans with light fixtures.You will get this clip from local ceiling fan repair shop or from radioshack, homedepot or from walmart store.There is exactly not a part number but this pins are called ceiling fan clips. -------- if incase you dont get required clip or any substitute clip for fixing.Then you can get it from dealer.Click this link below to directly contact dealer:--- http://www.casablanca-ceilingfan.com/customerservice.html ----------- Also there is one more part site for casablanca fan parts:--- http://www.fanmanlighting.com/shop/pc/viewCategories.asp?pageStyle=h&ProdSort=19&page=1&idCategory=42 ------------ This should help.Thanks.Helpmech.
Jul 12, 2011 | Vacuums
I've never had to change a CFL bulb like the GE 35972 in my kitchen ceiling fixture. It looks like a squared off pretzel with the socket in the middle and facing up to the ceiling. It's been in there for...
CFL bulbs are held in place by a friction fit, but it is a very tight fit. Grasp the CFL by the sqaure plastic base and pull firmly away from the socket. You may have to wiggle it a little, but don't try to pull it out by the globe because they are very fragile and break easily. I would imagine the pins would be interchangeable with some other model, depending on the number of tubes and the number of pins. Just take your bulb with you to compare. If you have any specialty electrical supply houses in your town, that would be a great place to look. I'm giving you a link where you can order them if all else fails, but CFLs have become pretty common, so you shouldn't have too much trouble finding one.
http://www.e-conolight.com/lamps/lamps-compact-fluorescent.html
May 01, 2011 | GE Vacuums
Hello I have a hapton bay flush mount ceiling light fixture. The bulbs broke and I would like to replace them, however I seem to can open the fixture. It does not have a screw. Please help me. Ingrid
Hello, W/D here.
Try pulling (firmly, but not too hard) straight down. Most fixtures without screws holding them on will have a spring clip inside the globe to hold it to the fixture.
Best regards, --W/D--
Apr 03, 2011 | Vacuums
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Mar 05, 2008 | Vacuums
Alto 302000414 Attix 8 AS/E Canister Wet/Dry Vacuum Logo
55 people viewed this question
Top Alto Vacuums Experts
Are you an Alto Vacuum Expert? Answer questions, earn points and help others
