Question about Dishwashers
After pushing on button, cycle begins and light comes on momentarily and then stops. Cycle does not proceed. Light goes off.
  • Dishwashers Master
  • 5,603 Answers
Possibly the door switch is opening. Try holding in the door and starting. If it continues as long as you hold the door, adjust the door interlock switch.
Posted on Nov 14, 2009
Why does my dishwasher stop during cycles and the cycle light blinks?
it has few functions , so break them down to this.
does water flow in correctly . hot an cold
does the pump re-cycle water well inside . reflow lots of spray.
then does it pump out correctly an flow easily into garbage disposal , check the back flow valve for stoppage if it has one {its in the large plastic pipe right before the disposal.lets water flow but compactor garbage is blocked, it sticks a lot closed }
and is the door latch secure test it by opening suddenly is all you can do.
you might have to open the door quickly to check these items like spray or pumping.
Aug 03, 2014 | Whirlpool Gold Dishwasher with Quiet...
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer will not Spin during SPIN CYCLES
check the lid switch on the washer its below where the tab on the washer lid that goes down in the body of the washer there two screws at the base of the control panel back these out and raise the panel you will see a connector coming from the washer disconnect it and put a jumper wire where it goes to the control panel turn it to spin pull out the knob if it spins replace the switch if it doesn't reply to me and we will go from there
Jan 30, 2008 | Kenmore 22422 Top Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Jul 01, 2006 | Kenmore 24 in. 16293 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
