Question about Samsung HCN653W 65" Rear Projection Television
HCN653W Yellow tint and perfect focus.
Ok so I had an opportunity to pick this tv up used from were I work for $150 bucks. I figured what the hell if it has a few problems I can fix em and have a nice huge hdtv for very little cash. So my first problem is the perfect focus freezes at about 3% and won't work, now having done some research I figured out the replacement part is cheap and easy to do yourself, but the biggest single problem is my entire screen has a yellow tint, such as whites equal very light yellow and everything has a washed out yellow tint, what I need to know is will fixing the perfect focus fix this or is this an issue with the crt guns? If it is the guns which on the 3 should I replace or is there some other route I can take?
Thank You
    Genius:
  • 1,030 Answers
Yellow tinting is a indication of browning or alge growing in what is known as crt fluid also know as glycol. although this can occur in any of the three tubes blue is your most likely tube. dirty gylcol can be changed. but is a involved repair. you have to remove the tube. remove glycol disassembel tube clean thoughly with denatured alchol. reassemble fill with clean fluid ..replace tube then align and reconverge. as a tech aournd a 2 hour job
the dirty glycol can also cause the perfect focus to fail as the sensors cant "see" through the fluid. this is a very common problem on these units
Posted on Jan 08, 2008
Yellow tint with hd cable on tv
I do not understand what the question here is? one cable works ok but the other does not.
Aug 30, 2012 | Televison & Video
It has kind of like blurry lines going accross the screen?
my tv also had wavy lines when running thru the cable jack or your standard RCA jacks. i used a S Video cable to hook up my cable and dvd player... with no lines. they are about ten bucks at walmart one of the componets on the signal board.. my dvi also works without any lines. just for the record ihave been fixing tv's in my garage now for about a year all these experts say they cant fix that with this model tv i'll try picking up a parts tv and changing what i think has gone bad inside this tv and let everyone know.. but i have told you a way to get around it and get back to watcing your tv without any of those annoying lines
Jan 25, 2010 | Samsung HCN653W 65" Rear Projection...
Mitsubishi tv problem
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Reverse fisheye!!
you are going to need to replace the convergence board assembly. It is available at http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP95%2D00142P&search%5Fmodel=HCN653W. Also get the service manual, as you will need to do some touchup convergence and reset the perfect focus setup again If you have the technical ability. If you do, great! If you do not, these service menu alighnments can mess up your set, so take no shortcuts. Good Luck
Mar 29, 2007 | Samsung HCN653W 65" Rear Projection...
65 Inch Samsung Projection TV- Shaky Picture
have a tech look at your tv it needs to be repair checks can be made in the power supply.video circuit,or the IF CIRCUIT.good luck.
Apr 01, 2007 | Samsung HCN653W 65" Rear Projection...
Out of Focus
if you have no experience repairing TV sets your going to have to have a tech replace the convergence ICs they are soldered into place and will probably need to be readjusted when this is done. if you know how to work on tvs then replacing the STK type ics in a pair is whats needed Good Luck
Aug 16, 2006 | Samsung HCN653W 65" Rear Projection...
Convergence drift
Well, problem is that your TV is just too big... ;] Most probably you're looking at a job that includes replacing some STK chip on the convergence board, or the board itself. in parts a chip should be around 5 bucks, and the board over a hundred. Good luck
Jan 20, 2006 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
239 people viewed this question
Jerry Greenberg
Jerry Greenberg
