Question about Ricoh Aficio GX3050N All-In-One Printer
I have a Ricoh GX 3050N printer. It says ''Ink depleted''. Any reset zero method for this, apart from change a new one? ( prepfer this because I find that the GC21 series cartridges can be refilled to reuse. Therefore if I can find a method to reset the printer/cartridge just like those in Epson printers, it would be great for everyone.)
SOURCE: ricoh 3050n Gel Printer
Don't turn printer OFF, keep it ON all the Time
Posted on Oct 30, 2008
  • 17 Answers
SOURCE: INK DEPLETED BLOCKING ALL FUNCTION
Both of the cartridges did need replacing; the black is OK now so just pop in a cyan and you should be fine.
Posted on May 27, 2009
Matt_Sr
  • 31 Answers
SOURCE: Printer Ricoh Aficio 1515
delete drivers and reload, make sure you're using PCL 5 drivers.
Posted on Jun 18, 2009
  • 68 Answers
SOURCE: I have a Ricoh GX 3050N printer. It says
you will have to change all the cartridges together then power cycle the printer to run initilization to reset the toner condition.
if this resolves your issue please rate my answer accordingly
regards
Posted on Sep 14, 2009
SOURCE: Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
Posted on Sep 28, 2009
Rich Aficio GX e3300n ink smears on every print. I have cleaned and flushed heads. Still have the same problem.
Contact Ricoh and talk to the tech support guys. The print heads are shot. They might send you a replacement printer and have you return that one in exchange.
Oct 30, 2013 | Ricoh Aficio GX E3300N InkJet Printer
Ricoh gx3300n Blinks lights on start but fails to power
Your printer is fried but i bet you figured that out by now. You using Saw grass ink i bet. Well thanks to them you now have boat anchor. The ink destroys the printer. I got one 2.
Aug 25, 2012 | Ricoh Aficio GX E3300N InkJet Printer
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
I have an errer 993 with my printer aficio 3050n and it can not print please help me it is urgent
it could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA.
May 17, 2011 | Ricoh Aficio GX3050N Printer
May 27, 2009 | Ricoh Aficio GX3000 All-In-One Printer
Have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Mar 23, 2009 | Office Equipment & Supplies
Ricoh 3050n Gel Printer
I brought it in for our tech guy at work to look at. He doesn't charge. Why can't I get any suggestions on what to look for?
Mar 03, 2008 | Ricoh Aficio GX3050 GelSprinter
Ricoh Aficio  GX3050N All-In-One Printer Logo
234 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
