Question about Fujitsu 24C1 Air Conditioner
What is the dry function for on the remote control?
  • 400 Answers
This is used in very humid conditions to dry out the air in a room. Specifically if you are near the coast.
Posted on Nov 18, 2009
Remote works with on and off and volume but stopped all other functions.
1 Remove the batteries form the remote and blow hot air by hair drier about 5 seconds . replace the older/ used batteries with new one of same kind. Does it solve your problem ?
2. Remove the batteries and unscrew the remote and then open the case of remote , clean the PCB's key pad area with soft and dry cloth , put small amount of carbon ink (purchase from electronics parts shop- cost $0.5 approx) on key pad's back side round dots, let it be dry for 30-45 min , assemble the remote and fit batteries and enjoy.
May 27, 2016 | Universal Remote Universal Genesis Remote...
Function keys advance on their own
Does this happen only when you use the remote control? If yes, remove the battery and return it. If this does not work, there could be bridge if there has been liquid splash on the remote previously. You need to remove the battery of the remote control and try to allow it to dry, it opening it is possible, then gently clean phase and allow to dry before coupling it back. Hope this helps
Dec 31, 2013 | Samsung 1000W 5.1-Ch. 3D / Wi-Fi Blu-ray...
Immobilizer fault on a Picasso hdi 2001 car starts
Take to dealer to reset the key code on the ignition key.
Oct 08, 2013 | Magnum Remusshield Finger Touch...
Mx980 got wet
USE A BLOW DRYER AND DRY COMPLETELY.. OR LET IT SET FOR A FEW DAYS WITHOUT THE BATTERY... AFTER GETTING WET IF YOU DON'T REMOVE THE BATTERY IMMEDIATELY THEY COULD GO BAD.
Mar 15, 2012 | Universal Remote Control MX980 LCD Remote...
Have a protron pltc-26 and the remote qiut working put in fresh batteries but will not turn on tv
The remote control is dead or the remote CPU chip that control all functions is dying and only some of functions buttons will work,some wouldn't anymore or the rubber insulater between the rubber buttons and the remote circuitry board are worn out and make no more contact.Can u take the remote aparts?Yes.Check all the rubber butttons insulater see if they're still good.Tries clean the remote PC circutries board with some rubbing alchahol also the battery - + connections too.Wait like about 20 mins for the rubbing alchahol to completely dries.Putting it back together again an putting in new batteries,the remote control might work again.If not have same result.Try website like Remotes.com to buy an original or very close compatible remote for a replacement.
Mar 23, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Hi the volume buttons on my remote control don't function properly. Can I open somehoe the remote and clean the buttons? Thanks Tasos
Yes, use a soft towel with rubbing alcohol you can wash the actual remote pad with soap and water make sure its completely dry before you reinstall, clean the remote control contacts with the alcohol
Nov 08, 2010 | Samsung BN59-00599A Remote Control
Remote Control got wet and quit working can it be fixed or is there a replacement that has all the proper functions? TV Model #TLX-04240B Polaroid S/N JR7G4186730007543 Remote Numbers 66700ABA2-012-R ...
Since the remote got wet, remove the batteries and let dry or you can try to open it and use a hair drier to dry it.
If that after drying it still doesn't work, check this link to find a new remote control.
Oct 30, 2010 | Polaroid 4241-TLXB 42 in. LCD Television
All of a sudden the remote does not control volume of channel change
does it control other functions?if yes,the carbon contact under the those keys is removed,if you can open the remote control,look for alluminium foil and cut a small piece and place it under each key that does not function with a glue,allow it to dry and cover it back,it will work.
Jul 26, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
RCA tv and a zenith remote cl015
take a poop ans sculpt it into a new remote.
Oh, i would let it dry out in the sun for a couple days before attempting to sculpt, up to you.
Dec 01, 2007 | Radio Shack 3-in-1 Easy-to-Use Universal...
Remote Control does not function
the conducting ink coating inside the blisters is gone. carefully open the top portion,which is stuck like an adhesive tape conducting ink black or brown is available with a hobby electronic shop put a coating on the inside of the blister let it dry stick the cover again.  p.s. bose service will tell u it is not repairable
Jul 06, 2007 | Bose Wave Music System Remote
Fujitsu 24C1 Air Conditioner Logo
126 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
