Question about Speed Queen Washing Machines
I have a kleenmaid washing machine by speed queen kleenmaid model LWK24 7.5KG 710RPM spin could you please tell me where i could get parts on sunshine coast qld australia delivered dec 2006 think it might need a new motor
Kleenmaid washing machine some of its cycle will not work
Posted on Jan 16, 2011
Hi i have a speed queen toploder washing machine
It might need to be rebalanced or your connection are not tight.
Feb 01, 2017 | Speed Queen Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
I had my speed queen about ten years it washes properly when it come to spin it go very slow and with jurking movements what can be wrong please
Open up the front panel by unscrewing the three screws at the bottom of the panel and lifting the panel up and out. Please disconnect the electrical power supply first. Look inside the machine for the van belt between the electric motor and the big pulley underneath the drum. Check the condition of this belt as it might need to be replaced. ( badly worn over all, inner rubber area cracked badly, rough sides ect). TAKE NOTE: Replace with genuine Speed Queen part as a normal vehicle v-belt will not work. Pressing against the belt will be a small pulley attached to a swing arm under tension of a spring. Slight shortening of the spring might help but only as last resort.
Aug 12, 2014 | Speed Queen Washing Machines
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Oil is getting into wash water
Hi Bob just read your posting.I am afraid your gearbox is leaking oil into the water .This means to repair the machine your gearbox needs reconditioning or replacement and also the main shaft seal will need replacing.I am putting this posting as a clarification request because my brand of expertise is FISHER@PAYKEL but I have some experience with SPEED QUEEN and KLEENMAID,which are the same machine only different names.Posting this reply as a clarification request will still leave your posting up in the washing machine area for other experts to hopefully help you further.But I am 100% sure that your gearbox needs repairing.Please reply if you need further help or information from me.Good luck.<br />
Aug 28, 2010 | Speed Queen Washing Machines
How do I remove the agitator on my Speed Queen AA4211WE? There's no cap! It all appears to be one piece.
I just did that. Just pull up really hard. Now.. how to get that other thing off to pull the tub, I can't figure out, all bolts are removed.
Jul 27, 2010 | Speed Queen AWS45NW Top Load Washer
Speed queen washing machine mod kaw693 repair manual reqired
do you know where I can obtain a repair manual for my Kleenmaid KAW693 I need to replace the seals and bearings as it leaks a bit of water and makes a screeching noice when agitating. My email address is kerryn12@optusnet.com.au Thank you
Apr 28, 2009 | Speed Queen AWS52NW Top Load Washer
Bearing or gearbox noise on spin
It is a pleasure for me to offer some assistance to users all over the world. The problem you are describing to me is a very common for any amana, speed queen washers. The tub seal leaks and washes the lubricant from the upper bearing making the roaring noise in spin. The bearing needs replacement now, also the tub seal comes as a kit to rebuild all the sealing surfaces. It also does require a complete dissasembly to install the new kit plus the bearing. I would charge 3 hours labor @ 75/hr and the parts would be around $100 for the hub-n-seal kit and the bearing. However you may want to consider a new machine with a better warranty (extended warranties are a MUST these days......BUY ONE with any new appliance. Hope this helps let me know if you have any questions. Unfortunatly these Speed queen design washer have a myriad of design problems and this is only one of them.
Jan 01, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
553 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
