Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Maytag washing machine top load
Hi Mr. Expert,
I have a Performa by Maytag about 9 years old. Lately making loud banging noise and spinning violently towards the end of spin cycle. How do I fix it? Firstly, how do I open the cover or access to the entire mechanism? Please help. Thank you and your help is much appreciated.
  • 868 Answers
  1. using a putty knife or slim screw driver ,wedge it between the top of front panel and top panel.See picture  #1 inserting the blade is to push the release tab in so you can lift the top away from the lower panel.There are two of these tabs located one on each side of machine about 4- inches from the cornerMaytag washing machine top load - c5ab599.jpgPush the tab in and pull up on the top to release the panel.Once you have released the top panel there are 2 screws inside that are holding the front panel to the cabinet, unscrew thos and your fron panel is off.
Posted on May 26, 2008
Maytag performa pav3200 washing mach. very load shrill noise during spin
if you just bought it it probably is the shiping pin. it is a large boldt in the back of the front load machines, smaller pin in the side or rear on toploaders. it keeps the drum from spinning in transit. people forget to pull them all the time. especially if you installed it yourself. If that isnt the problem, try leveling it. Newer machines spin much faster than older ones and one tiny bit off level will make it rattle and shake.
Jan 06, 2013 | Maytag Performa PAV3200
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Mar 12, 2011 | Washing Machines
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
My Magtag Performa washer has been shaking in the spin cycle very violently lately. The floor has not changed, so I can't blame an uneven floor. I'm assuming the belt may need to be tighten or replaced. ...
first I would check your drain pump.. you may have something blocking the water flow... this will cause the water not to fully drain and your machine will have a out of balance load...a loose belt will just slip and make noise,,,
there is a panel in the back you can remove to check the drain pump...let me know if this is helpful...
Sep 13, 2008 | Maytag Washing Machines
How do you know if your belt is not functioning properly? During the wash and spin cycles the machine makes an outrageous noise. The washing machine is 7 years old, a Maytag Performa, Top Loader, Model #...
  • tilt the machine over and look at the bottom. the belt is there.
  • it will feel loose but that is normal. it is spring tensioned.
  • the noise is probably coming from the water pump, when they are bad they make a loud noise.
  •  turn the pulley around a couple times to see where the noise is coming from.
Jun 28, 2008 | Washing Machines
Maytag front load leaking at drum spider
Probably not. Sounds like bearings and seal is shot.
Sep 08, 2017 | Washing Machines
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
180 people viewed this question
Dan Webster
Dan Webster
Sal De
