Question about Mitsubishi HS-U510 VHS VCR
When inserting a tape into the HS-U510 it ejects the tape.
When inserting a tape into the machine it makes a strange noice (screech) and rejects the tape.
You have bad timing, needs to put all gears in order.
and replacement of two rubber belts. to do right timing required service manual.
Posted on Mar 24, 2010
A worn belt and a broken spring.
Posted on Nov 14, 2009
HS-U510(c) Recently the tape is not rewinding. When ejecting, tape not rewound from heads and gets caught in mechanism. Defenitely seems to be some rewinding problem as noise of gears grinding and...
The problem is in the idler assembly that runs the tape and reels it in on eject, the drive belt will probably need replacing that is attached to the assembly.
Mar 27, 2011 | Mitsubishi HS-U510 VHS VCR
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Tape ejecting automatically
I found the spring on the tape carriage was off on one side. I reinstalled it and it fixed the problem
Dec 19, 2008 | Mitsubishi HS-U510 VHS VCR
Language setup for Mitsubishi HS-U510 VCR
I contacted Mitsubishi support. It is very likely the 510 and the 520 are similar. I was told to look at the back of the VCR (in the middle and lower) for a "timer reset" button. Pushing it will put you into initial setup mode and you can set your VCR to english menu. It works!
Ronrr
Jul 14, 2008 | Televison & Video
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Televison & Video Logo
280 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
