Question about Brother SX-4000 Typewriter
SX-4000 Having the same problem as others. I have not foung the keyboard setting 1 and do I need to press alt to get it back on track for good?
  • tjdale Jan 25, 2008
    Same problem as others. Machine types incorrect letters and I cannot find a "code-1" any place on the keyboard. Is the wheel bad? I have taken it out, put it back in, pressed code-reset. After this it will type the correct letters for 2-3 letters only then prints incorrect letters again. The wheel looks fine but I guess it is damaged or worn in some way. Is this correct or is there some other way the machine needs to be reset/callibrated?
How to set margin
Posted on Feb 07, 2008
How do I download brother SX-4000 electric typewriter?
If you are asking how to download to a computer file or a storage device, there is not a way without a major modification to your hardware (commonly known as a HACK to the device). Brother did not include a way to download from memory to a computer file.On the other hand, if you want to print what you have on the LCD screen you are typing in display mode. There are 2 typed of display modes (Line by line, and Auto) The way to print in display mode is;
  1. Press return if you are in Line by line.
  2. Type a complete page with and the machine will add the return when you reach the Right Margin.radarron_1.jpg
To determine what mode you are in, on the right side of the display you will see the operate section (see attached diagram) . If the triangle is pointing up you are in "Auto Return", if it is pointing down you are in "Line by Line" mode. If you don't see a triangle it should type as a normal typewriter (each letter as soon as you type it). To toggle through the modes hold the ALT key and press the OPERATE key. The keys that are activated by the ALT are color coded (same color as the ALT key) and are across the top of the keyboard.
Feb 15, 2011 | Brother SX-4000 Typewriter
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
How do you set margins
You move the carrier, with the space bar or backspace key, to where you want the margin to be set.
If the carrier stops before you get to where you want to set the margin, then locate the ALT key at the bottom left on the keyboard, hold it down, then locate the key directly under the words above the keyboard that say M REL (the 3 key) and push it. Then move the carrier with the space bar or backspace key. (whichever direction you want to go)
When the carrier is where you want the margin set, hold down the ALT key and push the key under where it says L MAR (4) to set the left margin, or R MAR (5) to set the right margin.
The ALT key works with all the functions listed above the keyboard.
The CODE key works with the functions/charachters printed on the keys themselves.
Jan 03, 2011 | Brother SX-4000 Typewriter
How to do margine release
Move the carriage (print head) to the margin you would like to clear. When you hear the beep, hold down the [ALT] key and press [3]. Now use the backspace or the space bar to move the carriage to where you want the margin set. Now hold down [ALT] and press [4] to set the left or [5] to set the right margin. For your further reference, I have included the keyboard special key chart. You might need to download the pic and zoom in to read it.
Dec 07, 2010 | Brother SX-4000 Typewriter
How do I do a left or right margin release??
You need to release both the margins before being able to set them again or to get rid of them all together.
To release the margins, you need to press the "alt" button and the number 3.
This should release both the left and the right margins, so if you only wanted 1 reset, you will need to set the one you wanted to keep over again.
Thanks,
Pat
Apr 09, 2010 | Brother SX-4000 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
How can I change the margins? for Brother SX-4000
Move carrier with the backspace or the spacebar.
Press and HOLD [ALT] while pressing the [4/$] key.
The left margin is now set.
Press and HOLD [ALT] while pressing the [5/%] key.
The right margin is now set.
Hope it helps
Oct 06, 2009 | Brother SX-4000 Typewriter
I need to re set the margins on my typewriter "brother sx-4000"
Return to the L. margin, press ALT & Mar. Rel keys, release the kets, backspace to location that you want the margin press alt and L. mar. keys.(4), Rt margin works the same.
Apr 28, 2009 | Office Equipment & Supplies
Reset margins
Above the number keys are words in green or blue the margin release, L. mar. and R. mar. are there return to the L. margin, press the alt key with the mar. rel. release them, backspace to the location for the L. mzr press alt and L. margin key, R. margin works the same way.
DickyO
Mar 18, 2009 | Brother SX-4000 Typewriter
Typewriter not typing correctly
check to see if their is a keyboard selection switch on the keyboard.
It may have a setting that says international, symbol, standard, etc.
Aug 11, 2008 | Brother SX-4000 Typewriter
Brother SX-4000 Typewriter Logo
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
