Question about Car Audio & Video
FACTORY 6 WIRE DVD FOR A 2004 SUBURBAN NEED TO KNOW WHAT WIRES ARE WHAT IE. IS THE ORANGE WIRE THE HOT WIRE AND SO ON . PUTTING THE DVD IN A 2004 YUKON THE THE WIREING HARDNESS IS NOT THE SAME AT THE DASH
SOURCE: pioneer avic-d3 in dash dvd player
By law you are not suppose to have video playing in the front of a vehicle becasue it is a distraction to the driver
Posted on Apr 27, 2008
Benimur
  • 6966 Answers
SOURCE: splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 13, 2008
  • 6 Answers
SOURCE: how do i bypass the emergency brake wire on a dual xdvd700
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Posted on Sep 06, 2008
Benimur
  • 6966 Answers
SOURCE: Jensen UV8 wiring issues
Appreciate the direct "Ask Me".
I am assuming that by your post "...the player worked fine..." refers to the unit operating as expected. To your concern:
  • clock resets;
  • dvd player light flashes on and off;
  • missing ding driver's door open.
All of the above indicates a wiring error or at the very least a loose connection more particularly to the mains B+ (always on). The always on B+12 is directly tied to the + battery terminal and as the name implies, with or without the key in the IGN SW, there is a +12. This always on B+12 is responsible for the clock to maintain its time, the memory of the headunit to retain presets tuner stations and all other settings. It is also responsible for providing the power to the "ding" circuitry and sensor. Pls re-check that the following wires are connected as indicated:
  • Yellow (with the filter/fuse) - always on B+12
  • Red - ACC +12 (ignition switch)
  • Black - car body ground/negative
  • Pink - Handbrake switch
  • Green/White (if present) - reverse switch on the gearbox
  • Brown (if present) - mobile phone in use mute trigger (if used)
  • Blue - to power a motorized/amplified antenna (if needed)
  • Blue/White - to power an external amplifier (if used)
Additionally, if I may inquire, year, make and model of the car it was installed in.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 11, 2008
j_del
  • 1586 Answers
SOURCE: 1998 Audi A4 Quattro rear speaker wiring
You can't use any of those - the large connector at the OEM speakers is because the rears are amplified. Your factory head unit puts out a line level signal to the rear speakers. There's an amplifier on the driver's side rear speaker (the box around the magnet that you can see from inside the trunk).
You need to either replace the head unit with an aftermarket one to drive your new speakers, or you need to tap into the amp connector and find the line level wires, break them out, put RCA plugs onto them, and plug them into an aftermarket amp, which you'd use to power your rear speakers. Doing it that way allows you to keep the factory head unit.
Posted on Oct 25, 2008
I need to know the positive and negative speaker wires from the door speakers on my 1999 ford expedition xlt. There isnt a marking on the factory ones and i want to put after market ones but dont know
white and orange are your positive wires. need-know-positive-negative-speaker-l0u5xrrbjmm23votbgnhzwek-1-0.jpg
You can buy some pigtails like this at a local car audio shop. No wire cutting involved, they snap right onto your factory connectors and aftermarket speaker terminals. Worth every penny.
Jan 12, 2015 | 1999 Ford Expedition
I have a 2004 suburban came factory with flip down tv / dvd side by side I add a second monitor for the third row like the cadillac I need to know where to find a harness or what wires to tap into to get...
If the monitor is in the headliner, you will have to get the wires from it. If the are in the back of the seats, the wires can be accessed under the back side of the seats. Beware, it is a small cable with at least 10 or 12 wires in the cable. I don't know what the wire size is, but it has to be size 60 or smaller.
Nov 22, 2014 | Cars & Trucks
Installing an after market radio harness but do not have a solid orange lead to connect out of the factoryharness
Most after market radios has a wiring diagram and the wires are tagged, but are wired the same, you should have two hot wires, one will be hot (12 volts) all the time for memory and the other will only be hot with the switch on. you can check with a test light, make sure your black wire is grounded. hope this helps.
Jun 03, 2014 | 2004 Chevrolet Monte Carlo
A 6 wire payne thermostat to a Honeywell rthl 3550,need to know where the blue-c wire and the o-orange wire go?
Orange is for a heat pump. c wire goes to common If you have a heat pump, otherwise just fold them up and tape them so they don't touch anything
Aug 31, 2013 | 2004 Mustang Factory Wiring Diagrams
I am replacinng the factory stereo with a JVC unit. The harness for the original has two orange wires, one plain the other with a black stripe, and the JVC one doesn't. What are these for and are they...
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
Apr 17, 2011 | 2004 Kia Optima
I have a 2005 f150 lariat super crew, I want to change the factory speakers and put some after market speakers, but my question is does anybody know how to tell wich is positive and negative in the...
For the std single or 6 disc changer, non DVD
Front
L + : Orange w/ Light Green stripe
L - : Light Blue w/ White stripe
R + : White w/ Light Green Stripe
R - : Dark Green w/ Orange Stripe
Rear
L + : Gray w/ Light Blue stripe
L - : Tan w/ Yellow Stripe
R + : Orange w/ Red Stripe
R - : Brown w/ Pink stripe
Dec 30, 2010 | 2001 Ford F150 Styleside SuperCrew
1993 dodge shadow radio wire diagram i have a problem with my instrument lights on the dash board speed,gas,temp,gages lights will not come on the radio light is on and it plays and works good but i have...
Hello! I will assume you are connecting a factory radio for your 1993 Shadow.
Remove the Orange wire from ground...Listed below is wiring from car to radio; You may need this one day...You are correct; There isn't a dimmer wire...The Orange wire, from the radio, connects to the Orange/White of the vehicle...Grounding the Orange wire is causing your problem...
1993 Shadow...Orange/ White=Illumination...Red=Hot at all times...Red/White=Switched 12volts...Black=Ground
Factory radio...Orange=Illumination...Pink=Hot at all times... Red/White=Switched 12volts...Black=Gnd.
Car; Orange/White to Orange of radio
Red To Pink
Red/White To Red/White
Black To Black
Let me know how you make out..
Guru...............saailer
Feb 04, 2010 | Car Audio & Video
2004 Expedition Wiring Color Codes
brown would be the parking light hot wire
green / white would be the blinker hot wire
black yes ground ,
but according to the schematics , **** this color combination only applies to the left front
the right front should be :
black ground , and a white / light blue would be the blinker hot wire
do you need the rear colors ?
brown is parking on both left and right rears
black is ground on both
light green / orange left blinker / stop light hot wire
orange / light blue right blinker / stop light hot wire
J5
Jan 15, 2009 | 2004 Ford Expedition
Parking brake hook up
This wire goes to the "Hot" side of the parking break switch... When the Parking Break is put on, a switch is closed, thus putting an "Earth" on this wire.. Ya can often bypass this by connecting to earth. Sometimes this wire can be "Hot" +12v so B4 doing anything with unit "On" check this wire for any Voltage.
Aug 05, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
