Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
Having a problem connecting my hdtv to my computer using an hdmi cable
    Genius:
  • 1,044 Answers
Try with Ethernet cable
Posted on Nov 14, 2009
No sound using HDMI
If you are connecting a computer using a HDMI cable, the audio does not go on the cable. You must use a stereo audio cable to connect the TV to the PC.
Jul 26, 2014 | Hisense 50 Class LED HDTV - 1080p, 1920x...
Tip
HDTV HDMI hookup
Connect a HDMI cable from your source device (cable box, Bluray, satellite receiver) to your HDTV for High Def video and audio. This is the best hookup for HD, even 1080p. For 3D HDTV, make sure to get a high-speed category 2 HDMI cable. Select proper HDMI input on the TV using the remote. HDMI means High Definition Multimedia Interface.
Any newer digital TV (made after 2008) should have at least one HDMI input.
https://sites.google.com/site/columbiaisa/diagrams_hookup_hdtv_hdmi
HDMI Cable
on Mar 06, 2011 | Televison & Video
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How could i connect this tv to laptop
Connect by this way:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Sep 16, 2010 | Samsung CW29M64NS 29" TV
Conecting laptop to tv
1. S-Video ? This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You?ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC?s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work. 2. VGA ? If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won?t find a VGA port on regular TV?s though, so this option is if you have an HDTV. 3. DVI - DVI stands for Digital Visual Interface with ?digital? being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80. 4. HDMI ? Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI. 5. Scan Converter Box ? This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Apr 07, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
I hooked up my HDTV with a HDMI cable but when I used the Audio L/R cables, I can't get any sound. I can get sound if I hook up the TV with regular cables but then I don't get the HDTV picture. Any...
You may have to go into the TV setup menu and change a setting for Sound (or Audio) that tells the TV which input to use (HDMI or component) for sound. Usually the HDMI connection will work automatically but if you connect cables to Audio L/R that may override the HDMI sound input.
Dec 07, 2009 | Televison & Video
How to use my HDTV for a monitor for my computer
What video output connection type do you have on your PC.....DVI, VGA, S-VIDEO, HDMI?
What video inputs connection types do you have on your HDTV.....DVI, VGA, S-VIDEO, HDMI?
The cable you need will be whatever connection you have....ie: DVI----->HDMI or VGA----->VGA or DVI to DVI.
You will also need an audio cable, 2 Phono RCA Red/White (Left and right) -------------> audio output jack plug or Optical in------->Optical out
Thanks
Sep 05, 2009 | E-Machines eMachines Desktop PC
Can't get HD channels selected on tv. Tried auto search with HDTV port connected and the menu selected to HDTV
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy, HD Installations
May 25, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
No right channel audio when using HDMI connection to HDTV
Since it is easier to replace, I would go with the cable box first. Sometimes there are software upgrades for the TV's that fix such issues but, almost all HDMI issues are with the cable box not the tv.
Jan 27, 2007 | Arris DCT6200 DTV Receiver
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
