Question about Samsung ML-2571N Laser Printer
Can anyone tell me how to change pick up roller in Samsung printer ml2571. Tks a lot!!! Bay ba
  • bay ba Nov 15, 2009
    Thank you very much for your expert help with very clear picture!!! This very helpfull!!
  • 1,113 Answers
Can anyone tell me how - d347f21.jpg Open front door, remove toner cartridge, inside centre you will see feed roller, press the two tabs I have indicated position with red lines, the actually tab I have indicated, with a green circle due to this picture of your feed is in seperated form.
You may have purchased just the feed tire or the entire roller, but either case remove by pussing tabs and rotating centre feed roller assembly clockwise.
Then you have to just pull off the old rubber tire and fit the new one and refit in reverse, hope this helps, sometimes it helps to have the feed roller positioned correctly, I have found that doing a print and pulling the power just as the machine first makes the noise of grabbing the paper then remove cartridge and now jammed sheet allows for better access to feed roller, hope I got my model right theres so many variations but i think thats your one, cheers
Posted on Nov 14, 2009
Red light stays on... wont print wont pick up paper... cleaned as much as I could...
There are a lot of conditions that cause the red light to come on. These include toner cartridge empty, paper jam, waste toner tank full, etc. The only good way of determining the printer fault is to check the smart panel software on your computer. It will tell you what the printer is experiencing.
If the printer can't pick up the paper, check the condition of the paper pickup roller. It is located in the back, and above the paper tray. Often it get dirty and cleaning it with a damp cloth helps it to pick up paper better. Hope this helps you.
Dec 29, 2010 | Samsung CLP 300 Laser Printer
I got problem with printer samsung scx4725, one part need to be replace is pick up roller, and next to it 2 plastic tab, oneis one missing. Pls tell me where can I download part. Thanks a lot!!
Try to clean the roller with alcohol first; it worked for me with the SCX4521-F and If you have already done it, search through google (sorry I don't know your'e region)
good luck
Nov 06, 2010 | Samsung SCX-4725FN All-In-One Laser...
My printer pulls multiple sheets at once.
yo have to:
1. Clear paper pick up roller whit wet cloth or alcohol
2. Clear separation pad (located under pick up roller) using same way as pick up roller.
Good luck
Jun 18, 2010 | Samsung ML 2010 Laser Printer
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
My samsung printer is not picking up the sheets of paper correctly and they seem to be sticking on the roller
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
Feb 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Not feeding paper properly
if in australia contact Laserfast.Your printer pickup arm assy requires changing.
Jun 21, 2009 | Samsung CLP 300 Laser Printer
Samsung spp2040 printer
The roller of the paper pick up is rotating or no. If rotating and not taking rollers need a cleaning try this else change the roller.
Mar 24, 2008 | Samsung SPP-2040 Thermal Photo Printer
Samsung ML-2571N Laser Printer Logo
198 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
