Question about Dual Electronics CECT P168 Cellular Phone
Can't dail from 5000+ - Dual Electronics CECT P168 Cellular Phone
How to make out going calls iphone?
Insert sim to iphone ..If its factory unlocked it will detect sim ..if not it has to be unlocked ..after inserting go to dail pad ..it has a logo of phone and dail the number you want to dail..then press the dail button below on the screen
Aug 18, 2014 | Apple iPhone Cell Phones
I cannot dail out on my line . I get a dial tone but cannot dail out.
Have you changed anything, or did this just happen?
Usually this happens when the lines get reversed on a jack.
It is possible that the lines were reversed coming into the house, or at an individual jack.
If you have more than one jack in the house, try the phone in another jack, and see if it works.
Feb 12, 2010 | Lands Phones
How do I fax multiple numbers at once?
You have to setup a group Dial.First setup yur one touch dail numbers under user mode-Tel registration,one touch speed dails.Leave at least 1 dail open and program it to a group dail number.Under usermode-tel registration select group dail and select your group from the one touch buttons.
Dec 14, 2009 | Canon LaserClass 720i Plain Paper Fax
How do i fax?
First you enter phone line in to the fax machine and then feed the fax paper on the top side of the fax machine then dail the number on the dail pad after the beep press the start button your fax start work.Fax throughput and office productivity are enhanced by scanning faxes into memory while the machine is busy. You can return to work, confident that their faxes will be transmitted as soon as the line is free.
Nov 25, 2009 | Brother IntelliFax-2480C Fax
Our company has a Panasonic kx-t7731 main line has no dail tone.
On that phone, press PROGRAM the button and dial 01 STORE.
Press program again to exit programming.
It's not likely you'll be needing the Group Log In/Out button.
Carl
Mar 12, 2009 | Panasonic KX-TA824PK Phone
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
Need to change 1 fax number in group dialing on a cfx-L4000 fax
All the numbers saved in group dail,are separatly saved in the one touch speed dails,you have to locate that fax number in one touch dails and change it there.
Nov 19, 2008 | Canon Laser Class 310 Fax
VTECH VT-2406 TONE- PULSE SETTING ?
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=373
Jul 03, 2008 | Vtech VT-2406 Cordless Basic Analog
Modem dialtone problems
Is the phone line going to the modem live?
Jun 25, 2008 | Intel Motherboard
Necchi Stitch Length
When you press the level the machine goes in reverse. When you turn the dail to O it goes in reverse. The dail is somehow out of alinement and that is what I am searching for the adjustment that would bring the machine to O and the adjustment that would lengthen the stitch forward. When I push teh level for reverse it does go in reverse. I guess the question would be if you would like to lengthen the stitch further than the dail currectly allows how do you do that. THanks!
Dec 12, 2007 | Necchi 3102 Mechanical Sewing Machine
Dual Electronics CECT P168 Cellular Phone Logo
Top Dual Cell Phones Experts
William Alequin
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
