Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
How Do I change the lamp on my Sony KDF55E 2000 TV
I was struggling with this same problem. The tv came with our house and the seller did not leave any manuals. We were going to give the tv away, but I started to google for information on how to change the lamp. We ordered our lamp from bulbsoutlet.com and it came with printed directions. The lamp was intended for the consumer to change it out easilly. On the front of the tv you will remove the bottom panel by turning the screws (by hand) on the back of the panel (you will have to wiggle the cover a little at the sides). Once it is out, in the center of the bottom section you will remove the large screw (by hand) that holds the cover in place. Once the cover is removed you will pull the entire lamp housing out, then just slide the new one in. The lamp cost me $130.00 and you do not need any tools for the replacement! My tv is almost better than new now! Sooooo easy! Hope this helps.
Posted on Dec 09, 2009
  • 52 Answers
Remove the cover on the side and remove the screw and lift up the latch and pull it out.
Posted on Nov 14, 2009
Sony tv kdf6oxs955 lamp red light came on,tv not turning on ,screen is black,whats the solution
If lamp light is on remove lamp and inspect it to see it is not shattered inside.
Life on these lamps is 2000 hours or 2 years average.
Suspects are Lamp or Lamp Ballast that drives it in that order.
May 31, 2012 | Televison & Video
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Overheat issue on kdf-50we655 sony tv
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
192 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
