Question about MSI RS482M4-ILD Motherboard
Which is the appropriate pin to connect audio out and mic pin
  • 634 Answers
If your CPU is vertical then you have plug your audio pin and mic pin at rear part.
If your CPU is horizontal then try to do this at front part.
And you can also find it as , howmany pins in your cable.
Posted on Nov 15, 2009
    Sergeant:
    Champion:
  • 240 Answers
These jacks must be identified on the back of the unit/board. Many boards use color coded jacks, usually pink for mic, green for audio out.
Posted on Nov 26, 2009
  • 535 Answers
This a basic normal pin for audio out and mic in pin
Posted on Nov 14, 2009
  • 832 Answers
Most motherboards with on board sound and/or audio card are fitted with audio in (symbol-arrow in), audio
out (speaker-arrow out) and microphone (symbol-mic)
etched at their respective outlet. If that is not present
with your motherboard, it means to say that you have to buy the soundcard, where these symbols are found. You
plug this in to your motherboard.
RCI 2970n2. What is the wiring to connect a Turner Plus 3 microphone?
pin 1 ground
pin 2 audio
pin 3 TX
pin 4 not used on other mics or has 8v on TX for powered mics
pin 5 not used on other mics
pin 6 not used on other mics
Jul 03, 2015 | Radio Communications
I am looking for a wiring diagram for the mic in, mic power and mic ground on a gigabyte motherboard 8vm533m-rz
"The front panel audio header on an Intel® Desktop Board lets you connect to a front panel audio module built into a system chassis. This document describes the header pin-out configuration for connecting a chassis with Intel® High Definition Audio (HD Audio) or AC'97 audio.
Note HD Audio headers are pin-compatible with AC'97 chassis and connectors. "
-intel Desktop Boards Front Panel Audio Header Pinouts
Sep 22, 2014 | Computers & Internet
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Headset
You use headsets to have conversations over the internet .. or to have a personalised audio equipment,.
You should have used the mic to start with, as you heard over the speaker your voice,
There are two pins. One for MIc and other for the headphones.
Use mic only when recording. other times keep it muted in control panel-> sound and audio...
you can use headphone for hearing when you don want the audio stream to be on speakers., TO use so, you have to take of the output from the CPU to the headphone pin after removing the speaker pin or configuring the audio controls control panel-> sound effect manager to have sound always in both theh speakers and headphones.
This requires you to have an appropriate configuration so that all 3 pins are aptly placed fot output from the CPU.
Hope you got what you asked for!
Apr 12, 2008 | Labtec C-322 Headset
Front audio connections
OK, let the speaker cable be your guide, its a for pin female connector, form there you should find your way.
let me know
Dec 15, 2007 | A-Top XBlade Mid-Tower Case
MSI RS482M4-ILD Motherboard Logo
167 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
