Question about Solis Master 5000 Espresso Machine
Wate coffee container removed for cleaning, the machine was accidently switched back on. Now the container will not slide back into the machine, it looks like the coffee maker portion needs to be re
The waste coffee box was out of the machine. The machine was accidently switched on, now the box will not go back into the machine. Seems to be an arm on the brewing group that will not reset into the flat position. Anybody know how to reset this?
You can remove the brew unit and cycle it manually back to the neutral position. There is an arrow and letter "N" that will align when the unit is properly positioned.
Posted on Mar 14, 2008
My miele coffee machine CVA4066 is not pumping water. The fault says "push water container all the way in" but it is in and its trying to rinse but the water is not going through the system. It is
I would check both the water tank and machine valves for sticking or obstructions first. Try placing the tank in warn water in to remove stickiness that may be keeping it closed.
Feb 02, 2015 | Miele Coffee Makers & Espresso Machines
Empty ground container issue
Once you have the drip tray out and the grounds container out - look inside the unit and clean any grounds that are still in there. Look for a switch that might be sticking (because it's cover with coffee residue) clean everything and check for freedom of movement.
Nov 27, 2014 | DeLonghi ESAM6620 Prima Donna Bean-to-Cup...
Hi, my tchibo coffee machine display is showing bean container empty when the container is full of coffee beans.I have removed the container and made sure it is there is nothing obstructing the tube.i have...
Hello
Push "Off" on the coffee maker's control panel. Unplug the coffee maker, and allow the machine to cool down completely. Remove the coffee bean container by lifting up on it and sliding it out. Wipe it out daily with a damp cloth, and slide it back into the coffee maker. Press down on the handle to click the container into place.
Dump out the water in the water container,Wipe out the water container with a damp cloth. Refill the water container with clear drinking water.
Remove the dump box and drip tray, and empty them.Wipe each one down with a damp cloth. Open the service door and push "Press." Remove the brew group by its handle, and rinse if off in a sink with hot water. Use the key provided to unscrew the plastic pin holding the metal filters together. Rinse each one separately. Put the filter back together and dry the separate parts with a towel.
Mix a package of descaler with the water in the water container every four to six months to rid the coffee machine of mineral deposits. Plug in the coffee machine, and select "On." Select the "Hot Water" button, and position the steam valve over the drip tray. Dispense two thirds of the descaler and water into a container in 15 minute intervals by turning the steam valve counterclockwise to dispense and clockwise to shut off the flow.
Let the coffee machine heat up fully, and then dispense the remaining descaler and water by turning the steam valve counterclockwise to empty the water container. Press "Off" to turn the machine off.
If this does not work then you might require a technician.
THANK YOU FOR VISITING FIXYA
Feb 10, 2011 | Coffee Makers & Espresso Machines
Hi there, I have a saeco incanto classic manual machine (had it for 1 week). The machine says it wants more beans (red light flashing) but it is full already. I have tried to empty the bean container...
The light comes on for two reasons. One is out of beans - the other is coffee cake thing is full. Sometimes the brewing device ( that big thing inside the door) will have a bit of coffee cake in it. Just take it out ( Squeeze tab and slide out) and rinse in sink. place back in. Very common issue so get comfortable with sliding this thing out to clean
Dec 04, 2010 | Saeco Incanto Classic Espresso Machine
Cannot remover the coffee grinder from machine.
Remove Coffee Maker's top cover. Slide coffee bean container off (after emptying it of coffee beans). Remove fixing screws (normally philips) securing the bean container platform. Remove grinder's bean intake rubber seal. Unscrew the grinder's fine/course selector, paying close attention to where it was originally fixed, from factory. 4 rubber bushing are anchoring the grinder in place, which can be seen from the front of the Coffee Maker (w/ door opened). Wiggle each rubber bushing through, as you pull grinder from the top. Grinder should come loose, after unplugging wires. - Good Luck
Nov 13, 2010 | Miele Coffee System
How do you remove coffee bean container from Miele CVA615?
There is set-screw that holds the cofee bean container from pulling all the way out. Loosening almost all the way out (or removing) the screw, will allow the cofee bean container to slide all the way out. However, when sliding it out, put a container under the edge of the machine housing to catch any residual beans and keep them from falling all over the floor. Here's how to do it: with the door open, look (or feel with your fingers) directly at the (closed) coffee bean container. Coming up from the bottom, all the way on the right side is the set screw. It's a black phillips screw that you can easily miss if you don't look carefully or use a flashlight as it blends in with the housing. Good luck.
Nov 12, 2010 | Miele CVA615 Espresso Machine
Removing Saeco coffeemaker dregs container
The dregs container comes out with the drip tray. Lift up on the drip tray and slide it out. If this doesn't work then the brew group is out of position. Turn the machine off then on so that the machine goes through a self test. This will reposition the group allowing removal of the dregs container.
Apr 24, 2009 | Saeco Incanto Sirius Fully Automatic...
I can't get the coffee grounds plastic dispenser back into the
remove the used grounds container and place a folded piece of paper where the grounds container touches the micro switch ( that is in a slot in the left side where the container enters approx 8cm inside) and then restart the machine and the grounds container will now be able to enter, remember to remove the folded paper before inserting the container
Nov 18, 2008 | Saeco Vienna Deluxe
Saeco royal coffe machine
Clean the central unit whenever the coffee bean container is filled, or at least once a week. If the water hose seems dirty it is probably due to hard water and needs to be descaled.
Descaling is done with a special citric acid you can buy in any grocery store or dealer of such machines. follow the directions and run clean water through afterwards.
To clean the filter:
Switch off the machine and open service door
Remove grounds coffee container .
Remove central unit, by holding the handle and shortly pressing the PRESS key. Wash the central unit with hot water; do not use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied with your device. Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
Remove coffee rest drawer and clean it, using a non-abrasive solvent. Clean the service area thoroughly and fit the coffee rest drawer again. By holding the central unit by its handle, slide it back into its original position, making sure it is correctly engaged. Then close the door. Fit the coffee grounds container again.
good luck, stephen
Jul 04, 2008 | Saeco Royal Professional Espresso Machine
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
Solis Master 5000 Espresso Machine Logo
119 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
