Question about Singer Inspiration 4210 Mechanical Sewing Machine
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed to go in?
    Problem Solver:
  • 6 Answers
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
    Sergeant:
    Habit-Forming:
  • Singer Expert
  • 106 Answers
Mine too. Any luck figuring out why?
Posted on Jan 17, 2010
Did you find an answer to this? Mine is doing the same thing
Posted on Dec 02, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
How to remove the bobbin plate?
Download the user's manual from the Singer site, www.singerco.com. It is a free download. Look on page 34, and it will show you how to remove the plate and clean underneath. There are two levers that must be set to release it.
Aug 11, 2014 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
My thread underneath the fabric keeps bunching up... how can I stop this from happening?
First make sure the bobbin is properly seated in the case, if it is, then you need to adjust your bobbin tension. that should correct it.
Tool Belt Diva
Jun 11, 2011 | Singer Inspiration 4206
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Threading problem on Singer Sewing machine Inspiration 4206
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
Dec 30, 2008 | Singer Inspiration 4206
I removed the positiong plate
I removed the posiotioning Plate(A). Singer Inspiration 4205. How can I get it back in?
Sep 23, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Singer Inspiration 4210 Mechanical Sewing Machine Logo
966 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
