Question about Kitchen Ranges
Code f1 on display - Kitchen Ranges
    President:
  • 1,462 Answers
Analog to digital failure. Disconect power for 1 minute. if the code comes back you have to replace the replace the control board...
Please leave me comment, if you need further assistance
Please rate this solution
Rnj Vinodkumar
Posted on Nov 14, 2009
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Runs 20 sec stops reads F1E5
    Error Code/Message - Oven - F1 Error Code - F1 E5
    Control displaying F1 E5:
    There may be a problem with the Oven Control, or the associated wiring.
    Power unit down by turning off the circuit breaker(s) for one (1) minute.
    Power unit up by turning on the circuit breaker(s).
    Monitor the oven for one (1) minute to ensure the error code does not display again.
    Verify oven operation.
    Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
    What causes error code F1 in my Electrolux convection microwave EI303BM60MS?
    Thank you for your inquiry, Leanne!
    From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
    Apr 27, 2015 | Electrolux Microwave Ovens
    Oven display goes into F1 error code and starts beeping. What is error code F1
    F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
    Sep 24, 2010 | Kitchen Ranges
    Trouble code F1-7 on display. What does that
    its confused. the problem maybe in you touchpad menbrane
    Feb 15, 2010 | Jenn-Air JES9750 Electric Kitchen Range
    Display shows error code "F1"
    F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
    Good Luck and Please Rate Fixya!
    Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
    Range displays e2 f1 and beeps every so often
    F1 E2
    1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
    error code is displayed.
    2. Disconnect power longer than 30 seconds.
    3. Re-apply power and observe for longer than 1 minute.
    4. If failure remains, disconnect power, replace control.
    Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
    F1-6 Fault Code
    This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
    Maytag Gemini fault codes.
    Fault code Suspect area Fault code Suspect area
    F0 - 0 None
    F1 - 1 Runaway cook upper oven
    F1 - 2 Runaway cook lower oven
    F1 - 3 Runaway clean upper oven
    F1 - 4 Runaway clean lower oven
    F1 - 5 Keypad cancel upper
    F1 - 6 Keypad cancel lower
    F1 - 7 Keypad disconnected
    F1 - 8 Keypad shorted
    F1 - 9 Slave
    Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
    F1 Displayed
    Carol, The F1 error code could be cause a failed ERC(EOC,Clock assembly)or a faulty touch-pad. To check the ERC and the touch pad, follow the steps below : -Disconnect renger's power cable. - Gain access to ECR's back. - Disconnect the ribbon cable between the ERC and the touch-pad - Reconnect renger's power cable and switch on. - If you will get the F1 and the beep,it means that the ERC is fault and should be replaced. - If you don't see the F1 code and don't have the beep, you should replce the touch-pad. Good luck !
    Jun 13, 2006 | Kenmore 92329 Electric Kitchen Range
    Kitchen Ranges Logo
    75 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
