Question about RCA RCR311B Remote Control
I just bought RCR311B and it wont work at all with my white westinghouse tv/vcr combo. I tried manualy entering the codes provided as well as using the auto program feature, both to no avail....any suggestions?
  • 325 Answers
Hello Sean,
Here is a link you may find usefull
http://www.universal-remote.net/rca.html
Hope this helps you out
Cheers Little Dish Fitter.
Posted on Nov 14, 2009
WHAT THE CODE TO PROGRAM A WHITE-WESTINGHOUSE OLDER MODEL TV
Hello
Three digit universal remote codes for White Westinghouse TV are:
097/ 100
Four digit codes are:
0227
0279
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK
Aug 05, 2011 | Westinghouse Televison & Video
I have white westinghouse tv/vcr the urc-4021b00 does not program
Helo
Westinghouse TV/VCR combo is not lited with One for all URC-4021 codes. OK.
Jul 06, 2011 | One For All URC-4021 Remote Control
I bought a universal remote for my tv vcr combo and the codes that came with it wont work i do not have the original remote what can i do
try these They are the main codes used by panasonic TV's and are from the most upto date book.
Panas on ic 0 0 5 1 ,0 2 5 0 ,0 0 5 5
on the UNIVERSAL select TV1 and SET light comes on and is steady, Enter CODE light goes out press SET
try the on/off if it works thewn it was the right code. If not try the next one using the same sequence.
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Panasonic PV-C2780 27 in. TV/VCR Combo
CODE FOR TURING TV OFF AND ON
My Sanyo TV will not turn on unless I use the rca 3-device universal remote to turn it on. I have lost the codes and instructions to the remote please help
Sep 19, 2009 | RCA RCR311B Remote Control
Remote won't detect TV
as it a learning feature if so perhaps it could learn from the original controller. i have had universal controllers in the past that are rubbish and certain makes/models can't be controlled...
May 03, 2009 | One For All URC-4021 Remote Control
Rcr311w codes for sansui tv/vcr combos
CLICK HERE for your user manual.
There are 4 ways to enter the code.
Thanks for using FixYa - A FixYa rating is appreciated!!
Nov 04, 2008 | RCA RCR311B Remote Control
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Code
www.rockabilly.net/files/manuals/URC-3220.pdf
Nov 26, 2007 | White Sewing Speedylock 1600 Mechanical...
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 14, 2007 | One For All URC-3021 Remote Control
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Oct 28, 2007 | Zenith ZN110 Remote Control
RCA RCR311B Remote Control Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
