The moto e5 plus uses a non-removable battery. The battery should only be replaced by a Motorola-approved service facility. Any attempt to remove or replace your battery may damage the product and will void your warranty. https://support.motorola.com/in/en/contactus
The Atrix 4G (MB860) has a removable battery.
The Atrix 2 (MB865) has a removable battery.
The Atrix HD does not have a removable battery.
I believe the battery for the original Atrix was SNN5865. but look for the SNN number on your battery and then you can look online for availability of that same battery. Please ensure you use Motorola Original batteries rather than knock-offs.
Do you need to Unlock Your Motorola Phone from Network lock? What is the correct model of the Phone.. BK70 is motorola phone battery model.You can check the mobile phone model,By removing battery and see the Battery slot or you can check it in motorola phone panel itself.Then get the unlock code for Motorola Phone at Simpleunlocking.com/motorola/rs16wp8/ and unlock it easily.
Do you mean where is a SIM card? If you have a Motorola V3 razr you will remove the battery door, There you will find the battery and just beneath it off centered to the right, you will find the SIM card. The battery needs to be removed in order to safely remove or insert the SIM card.
Unlocked simply means you can use it on any service provider's network.
You need to approach your provider for the settings to use internet, as the phone may have been set up for someone different before you. Unfortunately, thee are limited wallpapers in the phone, however you can change that by downloading pictures, or putting your own images on the memory card and selecting "set as wallpaper".
As for the battery, make sure you are only charging it when it's completely flat. You should get three days (max) out of it if you rarely use the phone.
