Question about EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit
Is it possible that my motherboard work even though the battery slot had a problem? my mother board is AMD M2A692-GDG
  • 832 Answers
It may work, since battery slot problem can be diagnosed as a loose contact problem. The problem can be intermittent. So you have trouble while doing a job
with that PC. So to avoid this, just adjust the bottom terminal, as well as the side terminal of the battery slot.
When you get this done, I'm sure your motherboard will
function normally. Unless, there are other defects.
Posted on Nov 14, 2009
  • 585 Answers
It likely will still work, it just will not retain the time, or any bios settings if powered down. Not much of a problem if it's never turned off
I have gigabyte m68mt-s2p mother board can i install amd radeon hd6670 2gb ddr3 graphic card on my mother board
The Radeon HD6670 should work in the PCI-e x16 2.0 slot. The 2.1 card is backwards compatible with the 2.0 slot.
The only problem could be your case configuration (you need about 8.8" of clearance). You also will need to check if your power supply gives enough power to run the card and the other components. AMD recommends a 400W continuous output power supply for a single HD6670 card.
I hope this helps.
Aug 06, 2012 | Gigabyte GV-R667D3-1GI AMD Radeon HD 6670...
I WANT TO BUY A MOTHER BOARD WITH FOUR SLOTS AND EACH SLOT CAPABLE OF TWO GIGABYTES OF MEMORY OR MORE
You could use a BIOStar N6853, which supports up to 8GB of memory. That is, if you intend to use an AMD motherboard.
Jul 15, 2011 | Asrock K7S8X-R3 Motherboard
Im having no signal to the monitor and a vga error on the mother board try everything
It means there is problem in your VGA Card. VGA Card is Built in OR Insert in PCI Slot or AGP Slot Just change your Card
Problem will be solve . VGA Card Drivers
Mar 12, 2010 | Biostar TA790GXE AM3/AM2+/AM2 AMD 790GX...
Inspiron 8600 does not charge batteries. Power
hello
As you have mentioned that power supply is working fine then there can be only two things.
  1. Your charging module in the mother board is malfunctioning.And you cannot replace a particular module, you have to replace whole motherboard for it.If your system is under warranty Dell will do it for free.
  2. The connector which connects the battery with the mother board is gone.
hope this will solve your problem
Thank you.
Aug 16, 2009 | Dell Inspiron 8600 Notebook
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
I want vga drivers of Jetway M2A692-GDG mother board.
The link would be
http://www.findmysoft.com/drivers/Jetway-M2A692-GDG-A06-bios-driver.html
Thanks.
May 24, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
HP a1712n How to troubleshoot MOB problem?
you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
Mar 16, 2009 | HP Pavilion a705w PC Desktop
USB 2.0 drivers
go to this site and you can download a usb driver for free
www.usbman.com
hope that helps!
thank you for using fixya
CHARCOIS
Dec 08, 2008 | Computers & Internet
Jetway M2A692-GDG tv out header pinouts ? can u find his specs ? 10k u or mail to goromi60@abv.bg
This link will give you pin outs for your PC's standard ports...
Click HERE
You can find pinout for your HDMI hook up by clicking HERE
It maybe more helpful if you will tell me what you are hoping to accomplish but as you have only asked for pinouts there you go.
Feb 13, 2008 | Computers & Internet
EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit Logo
49 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
