Question about Canon imageRUNNER C3200 Copier
Registration problem when using thicker board
Whenever I use thicker board, there is registration problem with colours. I was also looking for user / service manual. If somebody can help me in this regard.
  • 1 more comment
  • arunts Jan 11, 2008
    Thanks John for responding. I am facing typical problem where one half of board everything is perfectly fine but other part of the board there is slight registration issue. Do you still think is this pickup roller problem. Thanks again for honest reply.
  • arunts Jan 12, 2008
    I always use stack bypass for thick media. Whenever I feed standard weight paper by stack bypass, there is no issue. Problem is with thick media. Thanks.
    I always use stack bypass for thicker stock (220 GSM) and using the same tray, there is no issue when I use standard weight paper (100 GSM). This problem of registration is less when I feed sheets individually and happens more whenever I feed continously. Thanks.
Most likely if the tray has a lot of use the roller would have to be replaced. There are other possibilities. Does it do the same thing with standard weight paper? Have you tried using a different tray? What is the result?
Posted on Jan 12, 2008
  • 186 Answers
You should be feeding heavy stock through the by pass tray. This provides the paper with a straight path through the machine. If you are ding this, then the paper pick up roller may need to be replaced. It may be slipping.
Posted on Jan 09, 2008
Color registration
In user tools there is a maintance button press and then try color reg adjustment. If it doesn't sink color back in alignment it will say fail will need to call a tech . Could be anything from transfer unit bar that is shiny usually toward exit side cake with toner to laser failure
Jan 15, 2014 | Ricoh Aficio AP3800C Laser Printer
Colour misregistration mystery
Various possible causes - the most likely are :
1. Dirty registration sensors - remove IUs and transfer unit and inspect / clean sensors.
2. Damages / worn IU drive gears - inspect. Replacing the gears isn't a small job, if this is your problem.
3. Faulty colour registration shutter - you can check this is working in the service diagnostics menu.
4. EEPROM problem on the controller board - replace main controller board.
These are in order of likeliness. For further information, take a look here.
Nov 25, 2012 | Xerox Phaser 7300DN Laser Printer
Sc 400 error message?
If this for the MPC2050 range it is for the ID Sensor Board. The board reads the calibration off the Transfer belt to align colors. It can get toner drop onto the sensors. To clear this you need to open side door and release the transfer roller cover. if you look under the fuser section you will see the black thin cover that has two srews on is a round head. Remove these and then you will see the board it has about 8 screws holding it in place. remove these and release the board. Get a soft cloth and clean the sensor lenses. Replace board and covers. turn machine back on and press the 123 button to assess the user tools. go to maintenance and carry out colour registration. if the sensors are clean this should complete.
Jan 04, 2012 | Ricoh Office Equipment & Supplies
Hi. I recently purchased a used HP Deskjet 850C printer for printing high quality colour photos. The colours are great but the rollers make an impression on the photo paper making the photos useless. I...
Go into control panel on your computer and go into printer options you should see your printer icon in there. I think If you right click on it and go either printer properties or printer preferences theres an option somewhere you can choose what type of paper your using. If you choose a thicker type of paper it might help
Sep 22, 2009 | Office Equipment & Supplies
Colours are blurry
Registration problem, the color are not on top of each other looking blurrry. Service mode has a Regristration test that is run and can check registration
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2009 | Konica Minolta Office Equipment & Supplies
Any way to get a user manual for a Canon 2050 super G3 fax machine? Need to change preprogrammed phone #'s.
open the speed dial # flap look for data registration button and set button when you press data registration screen should change use the up down arrows and look for number registration press set then follow the steps anything you change you must press set
Dec 05, 2008 | Office Equipment & Supplies
Recently purchased a phillips 15nb5700 laptop.Set up wireless connection with sky broadband.So far so good.Then set up second user account but whenever i connect to the internet using the second user...
check your iexplorer default web page clear it.apply it and try again.
if problem remain then go to add remove windows components and clear check box on i explorer then reinstall i explorwer same way as u remove it just tick mark the i explorer.
Apr 03, 2008 | Computers & Internet
Dreamcast freezes.
take apart your dreamcast and look at the controller input circuit board, there should be a big resistor on near one of the boards corners, make a note of the coloured bands and buy a new resistor with the same pattern and replace the one already on the board with the new one.
Mar 09, 2008 | Sega Dreamcast Console
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
ADJUST REGISTRATION ON THE PCB BOARD AND ALSO THE BIAS VOLTAGES
May 13, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
41 people viewed this question
old marine
old marine
