Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
I have a kohler toilet that needed a new seat.
I have a one piece kohler toilet that needed a new seat. when replacing the seat we realized that there is no bolt on the underside to attach to. so the bolt goes right into the unit! no exit point. my husband even stuck his hand into the tank to see if it was there. nothing! the new seat just wobbles around. strangest thing i've ever seen. how to fix this?
  • vermillion66 Nov 15, 2009
    we are in a rental...the old one was stuck on with some kind of GLUE and bolts just shoved into the holes!! I fear we'll have to do the same with the new seat!
  • Ned C Cook
    Ned C Cook May 11, 2010
    How did the old one come off?
    President:
  • 3,433 Answers
Now isn't that a trick. Epoxy! The bolts,now studs, must be quite short. Well, glad you got it resolveve. I hope your house has more than one restroom..That epoxy will need a day or two toset up properly. :) Thank you for the reply. We all learn from each other.
Posted on Nov 15, 2009
  • Ned C Cook
    Ned C Cook Nov 15, 2009
    Look at some of the remedies on the other posts and good luck
Where can I purchase a new Kohler 85330-cp-17 Teal replacement molded wood elongated toilet seat for our existing toilet?
You cannot. As you state, it is discontinued, confirmed on Kohler site.
If color is really important, consider painting it or a new replacement using an appliance epoxy spray paint such as Rust-Oleum after careful preparation of the surfaces.
Jun 13, 2014 | 85330-BR-17 Part - Teal Assembly Seat-...
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
CAN'T IDENTIFY THE MODEL OF MY TOILET AND SEAT
Look inside of the tank the number will be stampes into the porcelin of the inside of the tank...
heatman101
May 26, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I can't unscrew the bolts on my Kohler 3386 rialto toilet to replace the toilet seat.
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
Dec 03, 2009 | Kohler K-3386-0 Rialto one-piece...
Broken bolt on toilet seat
your new seat will have bolts and nuts with it.
Jan 11, 2009 | Kohler - Toilet - One-piece - Santa Rosa -...
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
557 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
