Question about GE Televison & Video
GE Stereo Monito Input button location
I have an older GE Stereo Monitor tv with 2 inputs on the back. I want to play an x-box on this tv and I can't find how to get the tv to go to video one or input one. There is no input button on the monitor or the remote that I can find.
5 Suggested Answers
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
SOURCE: Switching Input on GE Stereo Monitor
I tried for a while to get my dvd to work. I went to the menu, from my universal remote that totally works. Went to the menu, then channel set up, and switched the VCR1 channel to 00Enabled. When I want to watch a dvd I press 00 for my chanel and it works. I hope this helps all of you.
Posted on Aug 17, 2010
SOURCE: how do I put the GE remote xs stereo monitor into
A good universal remote to use with that monitor is the RCA RCRN04GR, available at WalMart. I recently bought a 25" GE Remote Monitor XS Stereo from a Days Inn that was replacing all of those monitors with Flat Screen TV's. When I got it home I found that it would not go to channel 4 which was default with my COX Digital Cable Box. Channel 3 is the default channel on the monitor, so I ran an AV cable from the cable box, disconected the coax and hooked up the AV cable to the back of the TV and that solved the problem. I hope that answer was helpful.
Posted on Sep 03, 2010
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Posted on Sep 06, 2010
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
Dec 27, 2011 | Nintendo Super NES Console
How do I put the GE remote xs stereo monitor into input mode without the remote?
May 31, 2010 | GE Televison & Video
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
NOU SOUND
well I have a work around and a solution possibly. first go threw your menu audio and verify external speakers are not turned off. if there is no setting or it is turned on already try a different video/audio input if nothing else if you have good picture you can use a stereo reciever to play the sound you do not have to input audio into the tv if you have surround sound go straight from your device(dvd, vcr,cable box etc.) to your sereo reciever just the audio plugs (red and white, not yellow unless you have a monitor out from your stereo in which you conect all three to the stereo input then one cable from the monitor out on the stereo to the tv in put
Apr 14, 2009 | Televison & Video
Dec 13, 2008 | Televison & Video
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Input 5 not playing audio via HDMI or stereo
HDMI can be problematic. Follow these steps in order for the best success with HDMI.
1) With all devices off, turn the TV/monitor on first and wait for it to come on.
2) Select the HDMI input.
3) Turn on the next HDMI device (stereo amp if it comes before the video device, or the video device itself and let it come on.
4) Play the video.
Some video devices may need the audio output to be set to PCM or 48k/96k datastream to work correctly.
If this doesn't help, you may have a compatibility issue with your HDMI device. Usually it is the fault of the player/video receiver and rarely the display/TV. All the TV/monitor does is query the source device as to what type it is and the resolutions it's supports.
May 31, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Televison & Video Logo
99 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
