Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Start my drying runs for minute and dies and then i have to wait for 10 15 minutes to restart the dryer whats the problem
  • 68 Answers
Could be that your thermal fuse is on the way out. Also check your thermostats.
Posted on Nov 14, 2009
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
Dryer starts fine after a couple of minutes shutts of, I have to restart it several times untill clothes are dry.
most dryers have a sensor that is supposed to shut off auto matic when clothes are dry look at your choises on the dry temperture. one of them usually have automatic whites auto colors etc. the sensor sounds like it went bad. most of them are near the exhaust pipe.it measures the moisture level to test it remove the wire or wires. then try running the dryer for a little while.
Dec 29, 2011 | Roper Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Clothes dryer stops spinning before clothes are dry
sounds like a bad cycling thermostat!
May 26, 2009 | Bosch Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer stops running after 5 minutes
you may have a defective door switch.
Oct 27, 2017 | Dryers
I have a kenmore electric dryer. It dries for about 20 minutes then stops. If you wait for about 10 minutes and start it back up it continues to dry again.
Hello There,
1st- Check to see if your not running on overload with a clogged dryer hose the one that goes outside
2nd- your timer may be going bad or you have a bad sensor thats resetting itself.
Is this a newer model???? What year and model number?
Apr 02, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Mar 12, 2009 | Dryers
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
Dan Webster
Dan Webster
Sal DeAngelo
