Question about Maytag MSD2756G Side by Side Refrigerator
There is water collecting at the bottom of the Freezer. It is coming out of the vent area inside the Freezer near the bottom. Can you help identify?
  • 68 Answers
Check the defrost drain at the bottom rear of the freezer. If the drain is clogged or frozen, the water has to go somewhere during defrost.
Posted on Nov 14, 2009
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
Water collecting under bottom draws inside frig
That water is very likely dripping from the freezer because the drain for the defrost is blocked,so instead of the water draining its dripping through the vents down under the crispers. This tip i wrote will help ya to clear that drain to keep the water from dripping through the vents.
http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Magic Chef CTF1826AR Top Freezer...
My Refrig is collecting water in the bottom. My freezer is on top and the refrig is on the bottom. Water collects in or under the produce trays. What could be wrong
Without a model number or even a brand, this advise can only be general. You have a blocked defrost drain. Each time the refrigerator does an automatic defrost, the resulting melted frost needs to go down to a drain pain near the compressor, where it will evaporate. If the path to the drain pan is blocked, the water has to go somewhere, in your case, down the inside of the liner of the refrig and to the lowest level, under the produce trays. There may be a tube down the outside of the refrig on back which can be removed for cleaning, or the blockage may only be accessable from the area right by the cooling coils inside the freezer section. (usually located behind the back wall, but sometimes under the freezer section floor) You may find that flushing the drain tube using a turkey baster with warm water will be all that it takes to solve your problem.
Jul 14, 2010 | Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
I have Maytag refrigerator model MZD2752GR. Water leak from under the refrigerator for about 5 min a few times every day. What is the solution to this problem?
There is no one solution to this. It come from a variety of ways. For example a crack in the defrost condensate pan. Or a leak in a water supply line. The way you described it is almost on a cycle basis so I believe it is more of the leaking condensate problem. I would like you to look inside the freezer and fresh food section bottom near crisper and look for condensate buildup inside these areas condensate in freezer would appear as too much frost on items in freezer and fresh food compartment like moisture collecting on walls and shelves. Do that and let me know what you see. Pull front kick plate in front off and pull away from wall. Remove rear cover on compressor area. I will return soon, Thanks, Sea Breeze
Apr 13, 2010 | Maytag MZD2752G Side by Side Refrigerator
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Freezer leaking on Kitchen Floor
the pipe which is located at the back of the fridge/ freezer may be blocked or hanging outside of the designated collection chamber designed for this purpose. Unplug from the mains and pull the appliance away from the wall so you can see and get to the back of it. At the back of it you will see a pipe coming out from the bottom of the cooling fins and will go down and the end of it will be sitting inside a shallow plastic collection unit - not covered but open. Itusually is sitting on top of the condenser unit. (this is a large sealed metal structure whic has pipes coming out of it and is the largest item in that area at the back bottom end of appliance). If there is some liquid in it then either move the pipe end into the dry area or emty it out. Sometimes there isnt a collection chamber but the pipe just drips onto the condenser and evaporates - usually on self defrosting certain brand named products but dont know much about that. Use a pipe cleaner to clear out the pipes from inside the fridge out toward the back using that pipe. the drainage hole is inside the fridge at the back and may have some sort of cover or plug in it. remove that and clean it and use the wire or pipe cleaner to shove doen the hold and clear the entrance and exit. Test pipe functionability by pouring a small ammount of water down the drain hole and see it coming out of the back via pipe. If still leaking make sure the vent areas in the back of fridge and freezr are not covered expecially in the self defrosting models. basically dont overload the fridge or freezer coz this causes blocked vents, difficulty derfosting on self defrosters, water builds up and gets out via the tube as it should, but more water than can be evaporated will cause puddles on the floor
Jul 03, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water pooling underneath bottom drawers
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refridge leaking water inside it...
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
May 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag MSD2756G Side by Side Refrigerator Logo
154 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
