Question about Maytag MAH6700AWW Neptune Front-Load Washer
We had a power surge that popped the GFCI outlet and the circuit breaker, now the washing machine will not power up. The outlet has power but not the washer.
  • mikepotratz Nov 15, 2009
    what is the ecu and where is it located? I assume ecu is electronic control unit. How do your test it?
  • 77 Answers
Check the ecu
Posted on Nov 15, 2009
  • matlock_mich Nov 15, 2009
    Hi it is located in or behind the control panel.Part # is 34001479 it should cost around 217.00.hope this helps
Admiral washer. Did load of laundry, breaker tripped, and is still full of water. Reset breaker, and hear a small click after I pull knob to restart washer. Breaker trips. No leak, and outlet is good
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
May 22, 2015 | Admiral Washing Machines
When put on a wash it trips the electric
May 10, 2015 | Miele Washing Machines
Es-f800ks washing machine is power supply problem..That means is when i plug in the power then just 3 second only comming..after that no power..I try it many time ..It's same things..
Mar 29, 2015 | Washing Machines
Deawoo washing machin when start spin timer will triped elecricity
The washer tripped the breaker once and after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Mar 28, 2015 | Daewoo Dryers
My Kenmore Elite Oasis will not power up and I can not even get a error code. Circuit breaker is good what do I do? I am stuck on this right now!
r u sure circuit breaker is good? did u check the washer terminal black or timer for voltage??
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Mar 24, 2015 | Kenmore Washing Machines
When plugging it in to the socket it powers up only for a minute then trips the power any ideas?
Mar 22, 2015 | Washing Machines
Ground fault keeps tripping
Mar 17, 2015 | Washing Machines
I got 2 wascomat gen5 that trips breakers only on rinse cycle
LG Tromm washer tripped breaker, now won't come on at all
Jan 06, 2014 | LG WM0642H Front Load
When I plug my freezer to an outlet not gfi protected it works fine, but when I plug it into an outlet that is gfi protected it pops the breaker. I dont understand why.
All fridge and freezers should be plugged into an NON-GFCI protected outlet, since the inital start of the compressor can cause the GFCI to detect a millivolt surge, when the compressor starts, causing the GFCI to trip.
If this is in a kitchen, you should change out the outlet to a non-GFCI outlet BUT only to a single outlet that only has the freezer plugged into.
If it's in a basement, garage, or some other place with a GFCI outlet, you can change out that one outlet to a standard single outlet device of which ONLY the freezer will be plugged into and remain code compliant. You will need to make sure that any other outlets served by that current GFCI outlet stay protected, by installing the GFCI you swap out, and put it in place of the NEXT outlet in the circuit.
By doing that, you will have the first outlet that was the GFCI, now a single outlet NON-GFCI serving the freezer, but the next outlet in the branch circuit gets a GFCI outlet, thus protecting the rest of the circuit, in compliance with the NEC (National Electric Code)
If you need further help with this, please comment back and I'll check back later and provide you more detailed info. Of course, be sure to turn off the breaker to this circuit before making any changes to the outlets, etc.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | GE Freezers
Maytag MAH6700AWW Neptune Front-Load Washer Logo
182 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
