Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
Connecting Netgear USB adaptor to 2wire modem
I have a 2wire 2701HGV-W Broadband modem on one PC and trying to connect another PC to internet using Netgear WG111v2 usb adapter. I need basic step by step instructions.
Install the Adapter using the CD, After installing if its windows XP it will ask you to choose XP utility or Netgear utility, choose windows and scan for the network.
If its windows vista , go to start-Connect to - u will see the network name here , try connecting to it
Posted on Nov 14, 2009
How to get my 2wire ip number
There is a problem: you are connected on LAN side of the modem, so your IP is privat and are not visible in the Internet. It?s like 192.168.x.x .On the WAN side you have another IP that's could be public: 5.35.85.x .To see the public IP use a specific web site like: http://pingme.info/
Jan 01, 2015 | Gateway At&t 2701hgv-b 2wire Hi Speed...
2701HGV-E Power Broadband & Internet led in
Check for the user name and the password for the connectivity. Internet light red only means either the user name or the password is incorrect. Try entering the password and try again it should help.
Jun 21, 2010 | 2wire (1000-000057-000) Modem
Need help connecting a 2wire usb adaptor without the software
You need the drivers. An oversimlified analogy of what a driver is - drivers are what the computer uses to translate the language the devices speaks into a language the computer can understand. It allows the two to talk to each other.
You should be able to download the drivers for this device at http://support.2wire.com/index.php?page=download
The manufacturer for any device that you connect to your computer should have the drivers necessary to install it on their website. If the device you are trying to install is a network device (wireless or wired) and you are unable to access the internet, the best suggestion I have is to borrow a friends computer and a USB key/drive or have them burn a CD with the drivers on it for you.
Aug 09, 2009 | 2wire Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
Problem with 2wire adaptor connecting to Avenue Broadband
Yes, The DSL connection and Broadband connection are different with each other.
You'll needing to reconfigure the router as Dynamic and clone the MAC address so that it will recognize to the network.
- Try resetting the router and reconfigure the settings of your router.
Mar 05, 2009 | 2wire HomePortal 100 Network Adapter
Adding another computer to network
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Jul 19, 2008 | 2wire (1000-000057-000) Modem
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
Wireless Internet
I am guessing you are connecting that netgear card wirelessly? Does it get an IP address? Have you tried pinging the router from the laptop once the connection has been made? Try this. Go to the start menu, click the run button and in there type cmd and press enter. Once the black command prompt is open try ping yahoo.com See if that comes up with anything. Also try typing ipconfig and press enter. It will show 3 things.
IP address
subnet
gateway.
The gateway should be your 2wire modem.
Try ping gateway ip and see if that works.
Let me know! thank you.
Jan 27, 2008 | 2wire (1000-400108-001) Router
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
585 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
