Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi clu 615mp
TV won't turn on, power light comes on sounds like its going ,but no picture at all, left on for hours it will just come on on its own.Help
I had this same problem. To fix we unplugged it for a while, plugged it back in and it worked! Good luck!
Posted on Jan 15, 2008
    President:
  • 4,402 Answers
Sounds like a loose connection, check splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108 and convergenc ic for loose connections
Posted on Jan 09, 2008
How to fix fix my Hitachi Projection TV - model # 61WX01W, got darker and darker and now all dark. Has 3 pictures tubes. How do I fix the problem?
Likely what you have is the three tubes each have a filament--not unlike a light bulb-----someone would have to trace the filament voltage (usually comes from power supply) from source to the three tubes---filament connects to each tube with two connections and is usually 6.3 volts.
May 05, 2012 | Hitachi Televison & Video
Service menu codes for P42H401 plasma
PROCEDURE:
(1) With Plasma turned On, Enter the I2C Service Menu: (Remember, you are doing this without seeing a picture).
  • Press "EXIT" once, just in case TV Guide is brought up for Set-Up.
  • Press "Menu" and wait a few seconds.
  • Press "Menu" ~ "Menu" ~ "8" ~ "Select" Buttons on the Remote:
  • The Service Menu is entered, even though you can not tell.
Service Menu selection you can not see
  • To navigate and adjust while in the Service Menu, use the remote control's Cursor Keys.
Dec 31, 2010 | Hitachi P42H401 42 in. Plasma HDTV
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
No picture cant use remote to turn tv on/off or change station.
Hi,If I am understanding the remote control is not turning tv right? here's the one you need http://www.newtvremotes.com/Mfrs/Hitachi/HitachiTV/CLU-3842WL.htm God bless you.
Oct 02, 2009 | Hitachi Televison & Video
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 14, 2017 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Hitachi 60vf820 ultravision
Good Day, bgblueeyess;
Your somebody is wrong; replace the LAMP.
Good Luck, big IRISH.
Aug 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 60EX388 Rear Porjection TV
i think its the fan that needs to be replaced. or it could be the bulb.
Try to open the bulb assembly unit and take out the bulb and put it back in. If you have an extra bulb, replace it and see if works. This worked for me. The bulb i bought wasnt compatible
Mar 02, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
116 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
