Question about Akai Televison & Video
I have connected an Akai GX4 VCR to a small colour Orion TV, with connections from the antenna outlet to VCR and then to TV. How do I tune the VCR to the TV, so that the VCR acts as the main station tuner and the TV acts as a monitor only?
  • tonaltwo Nov 14, 2009
    Yes, it has the ability to act as a tuner (it has done this before but I can't remember what TV it was tuned to.) I thought there might be a signal or channel I could with but I can't find it.
    Guru did not seem to know anything about what I was talking about or the equipment I mentioned.
  • 350 Answers
You can by-pass the tuner if your Orion TV has Audio and Video inputs. Some have none while others do.
Connect your cable, satellite, or antenna to the RF or ANTENNA IN on your VCR. Next locate your VCR AUDIO & VIDEO OUTPUTS. Depending on the model of VCR it will have either two or three output jacks (RCA type) they should be Yellow for VIDEO, White for AUDIO LEFT and Red for AUDIO RIGHT if it's a stereo VCR, If not, it will have just yellow and white.
Connect the RCA cables (some call the stereo cables) to the output of the VCR and the other end to the TV A/V inputs.
Some VCR's have built in switches and as soon as you connect these cables, you'll get the output to the TV. Others have a switch either on the front or in the on screen menu to switch it to (AUX or LINE)
Turn the TV and VCR on and select the VIDEO INPUT on the TV that you connected the VCR to, this will be done on your TV remote which should have a TV/VIDEO button.
You'll now be able to select channels on your VCR to display on the TV. I hope this helps and good luck!
Posted on Nov 14, 2009
  • 4,924 Answers
You see...only if the VCR has the options and tuning properties you can do that ...if not it will act just like a regular antenna ...and will function on the AV mode of TV ...and the rest will tune and store in the TV mode..
there is another opotion to place the vsr with a regular antena cable and tune it by the frequency ..like a regular chanel ...but Im not sure how you will get the sound for it ...only if it has sound outlet ...for a separate sound system ..or amplifier ...or so ...
anyway ...if the vCR has a tuning for chanels option ...this will work in the AV mopde ( from the remote control) and plugged with an the RCA cable for sound and image ..
in this case ..the chanels wil be changed from the VCR ...by tuning or stored and stc...
  • Catalin Turcu
    Catalin Turcu Nov 14, 2009
    ok..there is no matter how you plug it with the tv ..cause the signal is processed into it ...and just the audio video goes out to the TV ...so ..it might as well be plugged with the RCa cable ...(see in the picture..)http://upload.wikimedia.org/wikipedia/co...
    in this case you will need to separately go for the video and audio ...in case that you do not have this kinda plug on tv ...just get a regular video cable that plugs into the antena ...or into next video if it has...
    just for the knowladge the RCa and the special video requires to set the Tv on the av mode from the av/tv on the remote control ..and will pic up audio video signal right the way ..
    the regular antena input will have to be tuned to find the signal from the VCR ...and than set like a chanel ....
    after that you just tune and browse chanels from the vcr
I have a mitsubishi black dimond vcr id like to tune into a sharp tv how do i do this please
Ok, to hook it up to use as a Receiver, and TV, as a "Monitor". Using the antenna cable, plug this into the antenna IN socket on VCR. Now connect up, AV, using the Yellow, Video, Audio, is Red & White, on BOTH TV & Video. Now select an EXTERNAL INPUT on the TV. Now You Tune, and scan for "Channels" using the VCR. Find each channel, and save, now, you use the VCR remote to change channels, and the TV, is used as a "Display Monitor".
The Other way, is to just use the VCR as a "Recorder only, you plug the antenna, into the TV, now at rear of TV, you have a Video OUT, Yellow, and Stereo, Audio OUT, Red & White. Connect up the VCR to the TV using them. Now anything you View on TV, will be out put to the VCR, when you wish to record, simply press record, on Remote/VCR as desired. and it will record.
Apr 08, 2010 | Televison & Video
I NEED TO KNOW HOW TO HOOK THE VCR UP TO THE TV SET. i LOST MY MANUAL I have PV-V4521
If you are using an antenna put your antenna connector into the rear of the VCR & then using a connecting cable (RF flylead), take this fron the other socket at the rear of the VCR & connect this to the antenna connector on the TV, you will then have to tune the TV to the VCR. Select channel zero for example on the TV, insert & play a tape, & then tune the TV in until it picks up the video playback picture then store this channel on the TV settings. Alternatly, do as above only use a Scart cable & connect this from the rear of the VCR to the AV connection on the rear of the TV, then when you wish to use the VCR channel, select the AV option on the TV.
Jul 11, 2009 | Panasonic Televison & Video
How do I hook up a VCR to a small Sanyo TV? Thank you
How you hook up the VCR depends on the connections available on the VCR and the TV.
The simplest method is to use a cable from the VCR's RF (antenna) output connector to the TV's antenna input connector and tune the TV to the VCR output channel (3 or 4). You might need to purchase an adapter to switch from the standard plug on the cable to whatever kind of external antenna connector is on the TV. If the set only has a built-in antenna and no external connection at all (which would be quite unusual), you need a "balun" transformer. This has a connector on one end for the cable from the VCR and a flat wire with two terminals on the other end. Attach one of the terminals to the set's antenna with a clip-on jumper wire. Radio Shack sells the parts.
If your VCR does not have RF output but just audio and video jacks, connect those to the TV's a/v inputs if it has them. Again, an adapter cable might be required.
If the TV doesn't have a/v input available, you need an RF converter. This takes the a/v signals from the VCR and produces a channel 3 or 4 output that you can connect to the TV as described above.
It sounds more complicated than it actually is. Once you look at the VCR and TV, and remember that outputs always go to inputs, it's usually pretty clear what needs to be done. If you still have troubles please post a follow-up comment and I'll try to help more.
Apr 22, 2009 | Televison & Video
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
How to connect my (old) vcr to my sony tv
if you connect via SCART lead, then you will need to select your AV channel or channels on your tv.
If its via arial, you will have to tune your tv to find it.
Mar 04, 2008 | Akai VS-X800EGN VCR
Vcr won't record tv
You have to plug the antenna to the VCR, in the "Antenna IN" plug, from there it goes to the "TV OUT".
You use the VCR to tune the TV and choose record according to your VCR model.
Hope That Helps!
Jan 26, 2008 | Televison & Video
Tuning a VCR into a digital tv set
Switch to using the A/V (Audio, Video) connections to watch your vcr
Dec 18, 2007 | Televison & Video
Orion model vpdc connection problem
Most, if not all, TV sets which have a tuner section (will tune in individual channels either off an antenna, cable system etc.) should be UHF capable. UHF channels are approximately channels 14 - 83 of the standard broadcast spectrum, unless this has now changed with HDTV or other RF spectrum changes by the FCC. These channels are not the same as the cable channels, for which the mode of the TV set must be set.
Anyway, you will connect the VCR to the RF input of the TV, and set the TV for non-cable mode (broadcast). You will likely need to set the TV for a particular channel which matches what the VCR sends the signal out on.
I assume also the VCR doesn't have composite video out & audio out jacks on it? If it does, these hookups can be made to matching connections on the TV.
Hope this helps.
Nov 05, 2007 | Televison & Video
Connection
Ok If you are connecting the VCR through the cable or antenna fitting on the TV set, you will have to see what channel the TV set has to be on. Look at the back of the VCR at the RF output and there should be a small channel switch. You also must tune the VCR in to recive cable channels unless you are using a cable decoder box. Good Luck
Mar 26, 2007 | Samsung SV5000W VHS VCR
Televison & Video Logo
49 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
