Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune fav6800aw fills then stops with clicking then Lr
I have a Maytag Neptune fav6800aw that I have loved for 5 years. We recently had a lightning strike and now the washer will fill and then you hear 2 clicks..one at the control board and the second at the motor board. The machine tries several more times (clicking) but nothing happens. Then 3 beeps and a Lr code. Thanks, Renee
  • 526 Answers
Hi Renee
I’m and owner and my wife likes the machine also…. except for the tangel problem :). Sorry to hear of your issue. This won’t be an easy DIY fix unless you have the following items I indicate in my fail point list. The three fail points that I suspect with a line impulse hit that could cause the Lr error code “Locked Rotor”
1. Failure of the Control Board. Motor control assy w/brkt (series 10) Sears, 25001079 ebay listing. 25001079 Appliance Zone
2. Failure of the Motor Control Board. 25001217 Sears, 25001217 AZ, ebay listing 25001217
3. Motor (but not likely). 25001034 Sears , 25001034 AZ , ebay listing 25001034
Some parts may have substitution part numbers.
If you elect to DIY here is some info you will need.
The Service Manual for reference. Sears Parts Direct for reference.
Did you have outlet surge protection at the washer outlet? If not I highly recommend surge protection on any electrical/electronic device that may be hit by a line surge. I’m out in the country and strikes zippe the trees, lost a well pump, Control Board in the electric range in the past. I Also had grounding issues that I took care three years ago when I relocated my main service entrance. I’m in the 19344 area and have a complete set of know good parts. If you were nearby I would offer to help. If you elect to repair I would have the service company bring at a minimum the first two parts. Call Maytag and find out if the control board is still under warranty. Contact info on the web and in the Service Manual. I got them to send me one.
Rich
Posted on Nov 14, 2009
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer top load neptune
See this post for troubleshooting the Lr error code. . http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
Lr is locked rotor. My first thought was that this could be a Motor Controller issue. This owner replaced tried that and it did not resolve the issue. He then replaced the main Control Board and that fixed his machine. Without known good parts (Control Board Motor Controller) this might be difficult for a DIY fix.
If you are going to try to DIY the repair I will see if I can help……Rich
Apr 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front lader washer maytag neptune
check the drain pump for a foreign object that maybe stopping the impellar wheel from turning.to remove the water use a shop vac attached to the drain hose to get all the water out
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My neptune TL displays the code LR.
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
Dec 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG NEPTUNE LR CODE
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune fronmt load washer Model MAH5500B
Lr means locked rotor basically you have serious problems i would call a service tech for this.
Sep 29, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washer stops after it fills up,& I get code "LR"
If the machine is only filling and draining, the motor could be faulty or the capacitor that controls the motor could be blown. The capacitor is situated in the control panel behind the controls. Remove the panel and test the capacitor. If capacitor ok have the motor tested. Also check if the belt is not slipping, worn or broken.
Sep 18, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
