Question about Sony Cyber-shot DSC-W55 Digital Camera
E:91:01 flashing and beeping few secounds after camera is turned on
I have never had any problems with my camera when all of a sudden I turned it on and the flash symbol came on the screen and then E:91:01 came on the screen then it started beeping and then it shut off. at first I could turn it on and take pictures but the flash would not work at all. Now I turn it on it starts to do all those things and then it shuts off. I have tried charging the battery does not work.
  • 5 more comments
  • Anonymous Jan 09, 2008
    My flash won't work on my Sony Cyber-shot DSC-W55 Digital Camera. It says 91:01
  • evgeni Jan 28, 2008
    yes i have the same problem
  • Anonymous Feb 20, 2008
    i also have the same problem. attempted to fix it following the instructions in the handbook, just like what you have recommended. yet to no avail. :(
  • jennyjenn Apr 15, 2008
    i have the same problem...thanks for the suggestion but it only worked for about 30seconds then the error came back....:( i have had a variety of problems with this product and don't reccomend it to anyone....
  • swervedriver May 05, 2008
    Same problem here as well. Takes pics but flash won't recharge and error code flashing on screen. Initializing is no help. Camera was purchased in Barcelona, SP back in August. Hope the warranty is good for repair in the US!
  • wkpkumara May 15, 2008
    suddenly flash is not working, flash symbol is blinking on the screen with E:91:01 please help.
  • Anonymous Jul 11, 2008
    my camera will take pictures but the only thing it does not do is change flash settings. i initialized my camera and reset everything, after that i could change my flash but the picture would not take. after that it went back to the blinking error.
  • 23 Answers
E:91:01 is a flash error you might fix it by initializing the settings of the camera but there is no guaranty.
1.turn the unit on
2.press the menu button
3. select setup
4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
6.if succesfull(you'll get clock settings)
7.set the date and time then try the camera again.
if this does not work.... call sony cust service 1800-222-7669
Posted on Jan 30, 2008
  • 1 more comment
  • grateful one Nov 12, 2010
    Thanks so much for this help. Just in case this helps anyone on my camera I had to press the Home button, then scroll to settings, then select main settings to find teh "Initialise" option. Reset my date and clock and all fine now. Thanks again avaya pimp!
  • balugedi Nov 15, 2010
    These steps resolved the problem.
    E:91:01 flash error is gone.
    i took a photo graph, camera flashed.
    i turned on and turned off the camera, then when i again turned on the camera, small sound heard and camera is switched off, hope the fuse burnt.
    even camera lens are not closed, i tried turning on camera but it is not turning on :( .
  • cha222 Sep 17, 2013
    THANKYOU SO MUCH!
If the problem persist even initializing the camera, the answer is a blown fuse. I solve the problem on a W50 replacing a fuse, in the picture (F1) 2A. Hope this help you. I suppose W55 is similar to W50 and others. Even if it's different, check all the fuses.
E:91:01 flashing and beeping few secounds after ca - ee60bed.jpg
Posted on Jun 18, 2008
    Novelist:
  • 178 Answers
The E:91:01 shows up when the camera flash won't work, or the auto flash , and themessage shows up on the screen Error E:91:01.
Fixing this problem requires a full diagnostic, and fixing it requires the appropriate tools. This fix is not recommended for the amateur photographer as you can cause more damage to the camera and further parts needing repair. This repair can be done successfully as www.TeleplanCameraRepair.com has the expertise to repair it and restore your camera to new! Their blog has pictures and more details on what happens and what the camera does when this error shows up.
http://www.teleplancamerarepair.com/camera-repair-blog/post/Error-E9101-Sony-Cyber-Shot-Camera-Repair.aspx
Posted on May 24, 2010
3 Suggested Answers
  • 48 Answers
SOURCE: E:91:01 flashing and beeping few secounds after camera is turned on
make sure its charged or check to see if anything has happened to it.
Posted on Jun 25, 2008
SOURCE: E:91:01 problem on sony dsc-w100
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Posted on Sep 03, 2008
Kodak easyshare C183 flash not working
Check settigns or possible burned bulb.
Aug 23, 2012 | Kodak Easyshare C183
When I put the sd card in and then turn power on it ask to format. no matter if I input yes or no the camera then shuts off
i have this w5 camera for the last 3 years few months back an error appear named E;91: like that and sometimes a beep sond for few seconds also on flash mode i cant take pictures i solved that problem by initialise the settings.now that problem started i initialise and formatted also remove the memory stick and again initialise and formatted but the error continues.i can only take pictures without flash what can i do please give me ur valuable suggestions
Oct 12, 2009 | DXG Technology DXG-572V Digital Camera
Turn the camera on, len opens up, camera make beeps
there is a problem with the lense motor. consult a good camera mechanic
Sep 20, 2009 | Casio Exilim EX-Z100 Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Aug 05, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Jun 19, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
5,411 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
