Question about Thermador Dishwashers
Thermador dishwasher runs for extended period of time to complete a cycle
We have 2 built-in Thermador dishwashers and each one takes approximately 3-4 hrs to complete a normal cycle. The water is hot before turning on the dishwasher. Any suggestions?
  • Doc Marino Jan 08, 2008
    The model number is DW246US/U12
  • 1462 Answers
SOURCE: whirlpool dishwasher DWF B00 W
get back to me and tell me if it drains or stays full of water and did you do work on the plumbing in the kitchin
Posted on May 14, 2007
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
Posted on May 30, 2008
  • 3 Answers
SOURCE: Whirlpool dishwasher installation
FOUND IT!!!!!
There is a white plastic screw in front of the dishwasher to estend the back leg!!!!!
Whirpool people are crazy!!!!
Max
Posted on Aug 19, 2008
SOURCE: dishwasher does not drain completely
the cycle was interrupted and now it will not drain completely. I cannot find the instruction manuel, and when I push the "clear/drain" button I hear the motor start but then when the light goes off the water is still in the bottom.
Posted on Sep 13, 2008
Is it true that it takes about 2 1/2 hours to go through a normal cycle? If not, how long does it take, approximately? I am asking about the 18 inch built-in.
I cannot find any mention of times for this particular machines run, I have found the Users Manual HERE. I don't think it should take 2 1/2 hours to run this unit through a cycle, perhaps 30 minutes to one hour.
I hope this answers your query.
Joe
Sep 20, 2011 | Danby DDW1899BLS Builtin Dishwasher
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
We mistakenly ran our 2 year old kitchenaid through a cycle
It's possible. A pump like that should never be run dry, especially if it ran dry for an extended period of time. Does the noise go away as more water moves through the system? If not absent then less?
Jul 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Go through cycle gets down to 1 minute and still runs for an extended period.
Does it run for very long past this time? The time remaining is only approximate and quite inaccurate. If its only a few minutes difference I wouldnt be concerned but if its more than 5 mins then there may be a problem.
Jun 13, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
May 27, 2008 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
104 people viewed this question
Top Thermador Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
