Question about Compaq Presario C700T Notebook
How do i reboot my cpu to factory settings, programs ect..?
    President:
  • 1,015 Answers
You can either use your recovery discs that came with the computer and re-boot the computer with the disc in the drive. The computer should ask you to"press any key to boot from cd" when re-booted. If it does not you will need to go into the BIOS and change the first boot device to the cd-rom drive. Or if your computer did not come with any recovery discs you can use the recovery program if it is built into the hard disc drive. You can usually activate this by pressing "alt" then "f10" when the computer first starts up. Sometimes the computer will tell you what to press to enter recovery mode when it first boots up.
Posted on Nov 14, 2009
I have a Seat Altea and need to know if I will encounter any CPU or alarm problems if I remove the factory fitted Blaupunkt radio entirely from the vehicle?
Radio's don't affect the security. But if installing another factory radio, it has to be programmed to your car. After market radios don't. If using an after market one, you will loose some chimes, like door,key,lights, ect...
Sep 03, 2016 | 2008 Seat Altea 2.0
How do I reset my computer to factory settins and will it correct the speed, also will I lose my setting, pictures, all down loads ect. ect.
by the system restore point which situated in programs-accessories-system tools
go for the oldest restoration point for your pc by this your all data will be safe only get renamed
Oct 16, 2012 | Dell OptiPlex GX150 PC Desktop
Hp laptop has blinking red square above touch pad, comp. won't allow for reboot or restoring to factory conditions
If you do an illegal shut down which is power off by holding down the power switch for 8 seconds. The HP computer will then boot with the scandisk program, which will restore your hdd to perfection. Windows XP or later now use 'system restore' to rearrange registry from a previous calender date that the computer used to work perfectly.
Feb 09, 2012 | HP Pavilion dv2911us PC Notebook
My advent 9617 laptop has started switching of after aprox 1-2 minutes, this hapens in bios, and also whilst booting up windows
reset bios to the factory optimal defaults ..cause this is happening only when the max temperature point of the CPU is set too low and it is reaching it in a few minutes...and shut itself down ...
by getting to bios ..and look for the line when it says optimal factory defaults ...it will remove any settings and suspicions in this direction...after that press f10 to save settings and reboot...If the issue is still on ..check the cpu cooler cause it is dead and it is not cooling the cpu and this is shutting down as a protection .....
also check out if it is charging ok ...it may be the battery ..dieing in minutes..cause it is not keeping juice anymore..
Mar 22, 2010 | IBM Lenovo ThinkPad T61 Notebook
I have a trojan virous
You are asking a big question here ... and the answer will not necessarily fix your problem.
Please go to www.majorgeeks.com and find the help you need to remove the trojan you believe you have.
If you still want to rebuild your computer from scratch, post a comment to your question so I can help you.
thanks for your interest in FixYa.com
Please vote
Have fun at Major Geeks ... an outstanding resource for problem virus's
please vote
thanks
a
Dec 05, 2009 | Kitchen Appliances - Others
High cpu usage, my laptop is so slow
Hi:
Most likely your laptop has too many things running, and other issues.
If you can, the best bet is to save all your important files and pictures, and do a system restore to factory specs.
If you can't do that, try some other things first:
Make sure you have a good antivirus program running on this laptop, and scan the entire hard drive. If you don't have a Antivirus program,
You can download a free one , that works well, at :
www.free.avg.com
Next, go to control panel, ad and remove programs:
work your way down the installed program list, and uninstall anything that is a trial program, any toolbars that you might have installed, or any programs that you don't want or need.
Next, run disk clean up , then disk degragmenter, and hopefully ;you gain back a little speed!
Nov 04, 2009 | Acer Aspire 1640Z Notebook
Vista start menu / all programs...
Download and install ccleaner.
www.ccleaner.com
This is a great little utility that you use to clean up windows and internet temporary files, clean your registry and most of all in the Tools>Start Up section view and delete or disable programs that start with windows.
The good thing about working in the start up section of ccleaner is not getting the reboot now and msconfig utility nag screen on reboot.
CCleaner is free by the way.
Aug 11, 2008 | HP Pavilion dv6000z Notebook
Restore factory settings
turn pc off with the system cd in the drive and reboot to cd. It will ask if you want to repair or install. Just follow the prompts to do a full reinstall. It will ask if your sure, and that all data on drive will be lost. Click yes and it will uninstall and reinstall everything to factory settings. Then boot the driver cd, and it will let you know what drivers are needed for your pc.
Make sure that your cd drive in bios is the first to start and not the hard drive. You can change that later if you want but I leave the cd drive as first so if there is a problem, I can use the disk to boot from. Also, only leave mouse,keyboard,and monitor plugged in. Unplug printers, scanners, ect:
After that, make sure you do all the update's and have a good antivirus program installed. I use Avast free and love it. Don't run 2 virus program. They will cause a conflick, so if you have one on the disk from the restore,remove it from add/remove first.
Good luck, it's easy to do and much easier that removing some of the virus's out there, and fixing some of the hardware conflicks
Jul 06, 2008 | Computers & Internet
Compaq Presario C700T Notebook Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
