Question about HP Compaq dc7100 PC Desktop
Ethernet port led blinking but port not show - HP Compaq dc7100 PC Desktop
    Sergeant:
    Champion:
  • 202 Answers
1. Your cable is bad or not hooked up correctly. Try another cable and make sure it's plugged in snugly to the computer itself, and the hub/router/switch/modem it's hooked up to
2. May be ur os corrupt.
3. if possible it disable 4m bios or registry.
plz chck it.
Posted on Nov 14, 2009
I have a switch Dlink (DES-3026). All the status LEDs are blinking together with orange color. Is there any problem in that?
Blinking LEDs show data activity (Send & Receive) at the connected ports. So, there is no problem as long as the switch is performing well
Good Luck!
CreativeTECH
Feb 01, 2011 | D-Link Computers & Internet
Good morning, how do I reset my Linksys SD2005 5-port Gigabit Ethernet Swith to default factory settings.
There is a tiny reset button on the back of the switch.
Power off the switch. keep the tiny black switch pressed and do not release that. Power On the switch and the sys LED will blink slowly and then rapidly. Now release the black button and wait for 5 minutes.
Oct 28, 2010 | Linksys SD2005 5-Port Gigabit Ethernet...
Why do my Ethernet and Internet light keep blinking?
Some routers blink to show there is ACTIVITY on the ethernet and internet ports, For example you broadband modem is connected to a port on hte back of your router this has a light it would blink on some routers to show activity, and likewise with the ethernet side.
If you have internet access and have zero issues this is NORMAL.
thanks for your question please do rate your answer, Thanks
Aug 05, 2010 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
Blinking light on NetGear FS108
One LED is a Link light that will blink on activity.
The other shows link speed.
These boxes have AutoUplink negotiation so no crossover cables are required.
Test again with a standard straight though ethernet / CAT5 cable.
Mar 19, 2009 | NetGear FS108 8-Port Ethernet Switch
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
For dummies
Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter 192.168.1.1. This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
Mar 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Link led blinking
WIRE AS U ARE USING WILL WORK FINE TILL 80- 85 METER. AND THERE IS DIFFERENT COLOR CODING EITHER U USE 10 METER OF WIRE OR 25 METER OF WIRE THERE IS A STANDARD COLOR CODE WHICH IS PROVIDED BY IEEE. I THINK THERE IS ANY PROBLEM IN YOUR SWITCH. IF YOUR WIRE IS OK AND PC ETHERNET CARD IS PERFECT THEN OBVIOUSLY ANY PROBLEM IS IN YOUR SWITCH. U CHECK IT PROPERLY EACH AND EVERY PORT. B'COZ SOMETIMES SOME PORTS PROBLEM CREATE HIS TYPE OF DISTRUCTION. GOOD LUCK PURUSHOTAM
Oct 01, 2007 | NetGear FS608 Networking Switch
3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
Nov 20, 2006 | 3Com SuperStack 3 3300 TM Networking...
HP Compaq dc7100 PC Desktop Logo
318 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
