Question about Lexmark X1150 All-In-One InkJet Printer
Lexmark solution printier
Please delete fax solution software its causing problems with me faxing on my fax machine three in one,I dont know how this computer fax,got on my computerit must be some type of electronic fax.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..that sounds like a settings issue..but we are not Lexmark, here..
    Genius:
  • 2,035 Answers
This for windows:::
Uninstalling Lexmark Fax Solutions
1. Go to Start, Programs (Win XP: All Programs), Lexmark Fax Solutions.
2. Click on Uninstall Lexmark Fax Solutions. The Installation Shield Wizard screen appears, displaying a progress bar.
3. In response to Do you want to completely remove the selected application and all of its features?, click OK to confirm the uninstallation. A number of screens will appear in succession.
4. In response to Setup has encountered application settings and data files. Do you want to remove these files and settings from your computer?, click Yes.
5. Click Finish to complete the operation.
Posted on Mar 24, 2008
I need a cd before i can fax
Download the software for the all in one machine from Lexmarks website. You dont need the cd to get the drivers to enable faxing.
Disconnect the all in one before installing the software and reconnect afterwards for the best results.
Sep 27, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
How can i use my fax with magic jack.using lexmark X2350
This is the answer that I got from the FAQ page.
SOMETIMES.
We do not officially support using faxing with magicJack.
Please try the following steps to use magicJack with your fax (contact your fax manufacturer for details):
  1. Turn off error correction on your fax machine or program
  2. Set the fax machine or program to use the slowest speed available
  3. Increase the speed, checking at each speed that faxes work
It seems that it depends upon the faxing unit that you use.
Mar 31, 2010 | Lexmark X2350 All-In-One InkJet Printer
I have Multi funtional Lexmark x342n machin. but i don't know,How to send fax from my machin.
have you installed the driver properly then good .in printer a fax printer is also installed when you install the full software of printer driver .for sending fax from any document choose the print option and in printer select the fax printer and send the fax.
but make sure fax printer is installed.
Jan 14, 2010 | Lexmark X342n All-In-One Laser Printer
Are you able to print out a fax that was sent out approximately 6 months ago
No. Not from a fax machine. Some faxes have the ability to store sent faxes but this feature caused more problems with memory filling up than it solved. So, the machine usually deleted the job after a short period and it is extremely unlikely that your sent document is anywhere near your fax now. Not a stupid question though.
Jul 09, 2009 | Lexmark Office Equipment & Supplies
Faxes
depends on what sort of fax machine or if you dont have one your computer modem and software, but yes it can be done and is quite common nowdays with most modern MFDs.
Jun 13, 2008 | Lexmark Office Equipment & Supplies
Fax problem
Pending faxes are faxes whose transmission has been delayed either deliberately or unintentionally. Normally, when a fax cannot be sent at the first attempt, the fax machine will redial the recipient's number. If you choose to delay sending a fax, the machine will send it at the time you select for transmission. During the delay period and at any point up to completion of the call, you can cancel the delayed transmission by deleting the fax from the Pending Faxes queue. To do this:
Press the Fax button on the operator panel and then press Options (once only). The Pending Faxes menu will be displayed.
Press Select. If a fax is pending, the printer will display Cancel Fax (the fax number you dialed appears below these words).
Press Select to delete the pending fax.
In response to the Are you sure? prompt, press 1 for Yes ( 2=No).
Press Options (once only). The Pending Faxes menu will now display None.
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax mystery
I am having the same problem as you. I think that we need to activate the confirmation sheet but i dont know how to do it. Did you fix it ???
Thanks in advance,
_ting_
Jan 21, 2008 | Lexmark X7170 All-In-One InkJet Printer
How do I find out what my fax number is ?
Go onto Lexmark's website for support and download the necessary software and drivers for your model. Then install them and you should good to go. Once you do the install the software should guide you throgh the fax process.
Nov 29, 2007 | Computers & Internet
DISPLAYING FAX NUMBER ON OUTGOING FAXES
The machine will print out whatever fax number is programed into its memory not what line it is connected to.
Plug a standard phone into the socket that the fax uses and ring your mobile..
or if just dial your mobile from the fax (type in numbers press send) should see caller id on mobile
I think maybe your setup is a little more complex cause the T632 normally is just a laser printer but you must have the 3100 MFP Option.
manual link
http://www.lexmark.com/publications/pdfs/lexmark3100/eng/userref.pdf
Oct 18, 2007 | Lexmark T632 Laser Printer
Lexmark X1150 All-In-One InkJet Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
