Question about Mitsubishi WT-46807 46" Rear Projection Television
RGB on each side have a hard time lining up. After some time the screen will get fuzzy and then the RGB will line up. It seems to take longer and longer for this line up. Is this worth fixing or should I consider buying a new TV.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Mitsubishi WT-46807?
If convergence goes in and out you need to replace the two STK-392-570 convergence chips this set uses.
I have repaired a lot of these sets and sometimes the chips are flaky---convergence will come and go--in every case replacing them cured the problem.
Considering you can buy a pair of the chips on Ebay for about 12 dollars plus shipping if you or someone you know can do this repair--you can save the set and a lot of money.
Most shops are going to get at least 300 for this repair.
By the way-----I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR.
They tell you everything that you will need to do it and how to do it. The reason I have them is so many people here have asked me the same questions I composed them---I got 2 comments today from people who had success with the instructions.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE DO NOT HESITATE TO REPLY HERE- I am here to help people.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 14, 2009
  • 145 Answers
You have bad solder connections on the convergence board. when they heat up, the metal expands and completes the connection. when you turn off tv, metal constricts cooling down. just simple easy soldering. no parts need replaceing. very much worth saving the tv.
Hitachi 57S500 fuzzy/snowy line at bottom of screen, mostly on left side
experts are free to choose to or not to answer any question..
the issue is very vague so limits some answer, is the line colored, present when a DVD etc connected via rear inputs, or 3 d like in some way?
Sep 02, 2012 | Hitachi 57S500 57" Rear Projection...
Nothing showing up on tv screen, only fuzzy lines
hi,
exactly the same problem here. I could suppose its a firmware problem because it happen with or without the hard disk. I also checked "stand alone" the hard disk and it works properly.
I'm trying to find if its possible to start an automatic firmware reloading from an external USB pen connected to box.
May 06, 2012 | LaCie 1TB LaCinema Mini HD
What is up with my 360 when ever i play it for about 30min it shows green fuzzy lines down the screen of my tv and purple fuzzy lines down my tv screen and after those two happen sometimes it will have red...
well definitely video issues of some sort. if you have a second video cable (or hdmi cable if your unit supports that) give that a try.
*assuming that doesn't work Unfortunately it sounds more likely that it's an issue with the video card inside the xbox. this may be repairable by a professional.
if you have it under warranty i would contact microsoft for a replacement/repair https://myservice.xbox.com/en-US/Pages/Welcome.aspx or call Toll free: (800) 4MY-XBOX
~best of luck!
Mar 13, 2011 | Microsoft Xbox 360 Console
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
May 29, 2009 | Microsoft Xbox 360 Console
Mitsubishi WT-46807 46" Rear Projection Television Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
