The lint trap on my dryer is extremely hard to empty the lint sticks to it so bad I have to use a brush to get it out. It seems like it gets too much moisture in it. Is there an easy solution?
  • 5,911 Answers
If your electric dryer is developing retaining moisture inside the dryer vent, then you have a clog in the exhaust vent ducting somewhere. The moisture comes from condensation inside the dryer exhaust. As your clothes dry, warm moist air is exhausted out the dryer exhaust vent ducting. If you have any kinks, excessive bends, sags, or excessively long ducting runs, the can create choke points for lint to accumulate. Once the lint accumulates, it begins to collect moisture. As it collects moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becoimes so backed up that it begins to collect on, or near, the heating element.
If you have not checked the dryer ventilation any time recently, now may be a good time to do so. I recommend checking it about once per season to ensure it is not obstructed. Make sure you are also using the semi-rigid metal type ducting. It resists crushing, kinking, resists heat better, and resists rodent infestation.
NOTE: Mice are notorious for building nests inside dryers. Give them a warm place with bedding material and they will make it a home.
Make sure the exhaust vent is at least 12 inches off the ground. This will deter mice and others pests (like snakes or birds) from entering the dryer exhaust from the outside. If you place a cover on the vent, make sure it is of the louvered variety. Do not use screens. They will collect lint and clog easily.
An easy test to determine if you have an exhaust problem is to remove the dryer vent hose from the back of the dryer. Turn the dryer on and allow it to run. The air leaving the back of the dryer should be forceful and warm. If the air flow is weak, you need to check the dryer interior. If the air flow is normal, reattach hose and run the dryer again. This time, check the exhaust vent where it exits your home. Again, the air flow should be forceful and warm. If not, you have a clog somewhere in the ventilation ducting which will require cleaning.
NOTE: If you are using plactic ducting, get rid of it. It collapses easy, rips and mice will chew right through it.
In addtion, many home owners unknowingly will push the dryer against the wall and crush the hose behind it. This will also clog the vent and make the dryer inefficient. Leave about a 1 foot space behind the dryer for proper ventilation and ensure the vent hose does not get crushed. Semi-rigid hose will prevent this from happening.
If you have any questions, please let me know. I have seen this problem many times. Let me know what you find and if I can be of further assistance. I hope you find this information helpful.
Posted on Nov 14, 2009
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Amana gas dryer LG8319W/L2
try getting a lint trap brush its long so u can get all the way down in the trap try cleaning that first that is usally the problem
Nov 17, 2011 | Amana Dryers
When i pull out the lint trap and stick my hand in as far as i can, i can feel a large buildup of lint and I don't know how to get to it
you will need to open then dryer up and with a brush(paint or another soft bristled brush) and vacuum remove all the lint, might as well clean the vent tube out, here is a website that will show you how to open it up, Good Luck Tim:
http://www.partselect.com/dryer+open-cabinet+repair.htm
Mar 19, 2011 | Dryers
My whirlpool duet electric dryer lets so much lint get through. A lot of lint doesn't get caught in the lint trap mesh and is going through the vent. I can tell by what is exhausted outside my house. I...
yes fire hazard ---but you need to make sure the lint trapp is seated all the way down if it doesant seat the lint will blow pass the screen ,,replacment might be nesasary if trapp is damaged less than 20 dollers at most parts stores.
Aug 10, 2009 | Dryers
Lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Apr 20, 2009 | Whirlpool WED5100SQ Front-Load Electric...
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Lint filter sensor with Error Code: 01 constantly comes on after the dryer is in use for 5minutes or less. Screen is clean, vent from back of dryer to 3ft of flex hose to outside wall is spotless.
Sounds as though the sensor is dirty of faulty. I would recommend having a service tech out to check and replace. Also if the sensor is going bad, it may be tripping it due to the excessive heat.
Apr 08, 2009 | Bosch Nexxt 500 Plus Dryer
Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer. http://www.pcappliancerepair.com/model-display.php
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Regards,
Rick
Dec 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
