My printer seems to have lines throughout the entire job i've tried everything to no avail, could it be the head is damaged or could it be the cutting strip platten
  • 558 Answers
In the printer properties use the cleaning option there to clean the print head.If this fails you might want to try some Kleanex to clean the print head.
Good luck
Posted on Nov 14, 2009
Horizontal White Lines
My 1st thought would be clean heads also. If ink is tanks only not heads take ink out and try cleaning heads with liquid cleaner available @ Staples or similar stores. Another fix might be to use alignment utility for your printers software; however before you do any of this if ink is old or nearly empty replace ink.
Jun 13, 2013 | HP OfficeJet V40 All-In-One InkJet Printer
Ink smear on back of print job canon pro 9000
control panel - printers- highlight printer but dont select - top right printer preferences - maintance- clean printer heads etc clean with all options available. should fix the problem.
Feb 10, 2013 | Canon PIXMA Pro9000 Printer
I've got vertical lines down my photos
Usually happens when print heads have been damaged usually from inferior inks have print heads replaced if possible, If it is only happening with particular software try another printing program, If problem is present still either repair print heads if possible otherwise replace printer. I hope this helps
Aug 30, 2012 | Epson Stylus Sx400
My photosmarts ink cartridge keeps jamming after printing 3 to 4 sheets of 8 sheet printing job. I open the prniter and reset. It finishes the job but keeps happening on every print job. I am using HP...
You didn't refill them yourself, did you? HP cartridges seem to really hate anyone putting ink into them. They never seem to seal right after that.
I would try to clean your head contacts and the printer heads themselves.
You can use a soft cloth (like microfiber, like what you would clean glasses with) to clean the contact heads.
You can check with your manual to see how to do a print head cleaning. They vary by machine, so there is no blanket answer.
One other setting to check on, although it has nothing to do with the heads - be sure to right click on your printer
(Start>Control Panel>Printers>(your printer))
and choose the PROPERTIES. Click on the ADVANCED tab.
Make sure that "ALWAYS AVAILABLE" is chosen, and that you have the PRIORITY set to 99. That will give you the best printing possible.
Apr 28, 2010 | HP Photosmart 2610 All-In-One InkJet...
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Getting vertical lines throughout the entire print
I assume you went through all the Epson utilities trying to fix your prob so:
Try increasing the resolution (DPI) of your print jobs.
Sep 04, 2009 | Epson Stylus Photo R2400 InkJet Printer
It is printing a solid black band throughout the entire tape, and it prints inches and inches of it, much more than the text. Help
You may have ink on the print head. Try removing the back and taking out the tape. Using a dry Q-tip gently wipe the print head which sits just opposite the black rubber roller.
Also confirm your tape is not old. If possible, clean the print head and try using a new tape.
Aug 02, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
44 people viewed this question
k24674
jasbo
jasbo
