Question about Saeco Starbucks Sirena Espresso Machine
A peice(oring maybe) fell out of the steamwand while I was taking it apart. now the attachment will not stay on the wand it just falls off, can I get a new one?
  • 1,089 Answers
Hi
There should be 2 removable pieces between the cap and the main body. There should be a plastic compression sleeve, and a rubber sleeve. They should look similar except one is hard and the other is soft. The best way to clean the steam tip is to loosen the cap and pull the bottom of, leaving the other pieces on the wand.
Posted on Nov 14, 2009
Dyson DC25 -wand extension lost a spring and becomes disconnected during use. I don't know where spring should be?
The button you push to release the wand has a spring to allow it to spring back after the button has been released. If that spring is missing the wand will not stay attached.
Jan 10, 2017 | Dyson Vacuums
Why did the driver side window fall in the door?
Hi, Its likely not the window regulator. Something could have come apart or broke where it attaches, but you will have to take it apart to find out.
Aug 30, 2014 | 2002 Ford Escort
Simoniz wand
Pressure washer use special ORINGS not the round ones and a high pressure stream of water will cut skin! Did you purchase the oring from a simonize dealer or a box store?
Apr 04, 2014 | Garden
Steam wand on Vienna plus detached from arm
Lets first make sure you have all the parnello wand parts. The nut, hard plastic gasket, soft rubber gasket, the inner wand then the sleeve and the center in the sleeve. When putting it back together find the notch on the metal steam wand and slide the nut onto the wand, then add the rest in the order above.
Jun 02, 2012 | Saeco Vienna Plus Espresso Machine
I have a d51822 framing nailer that will shoot a nail but then not recoil to shoot the next nail, if you wait 10-20 seconds the gun will release air at the top of the gun and recoil
Most likely there is a problem with swollen orings between the cylinder and cylinder spacer (white plastic piece between cylinder and body ). Order the oring kit because nost likely when you take the gun apart the orings will fall apart. Dewalt used vinyl orings instead of viton on critical areas of the cylinder and these vinyl orings failed.
Sep 21, 2011 | Dewalt Clipped Head Framing Nailer
Low Pressure
I worked at a tool rental while attending college and had the opportunity to work on a variety of pressure washers, however, they were of the commercial type. Commercial washers are slightly different in that they usually have seperated components for easier service. Attached to the pump by fittings or rubber hose were the pressure regulator (which has the bypass unloader inside), chemical injector, pressure gauge as well as the hot water release safety all external to pump. Your pump has all these components in one case. By far the most troublesome component is the pressure regulator/unloader which when failing will result in low pressure because it will bypass water back into the intake as you suspect is happening to yours. Here are a few things to check. I believe that your pump is 2500 2.4 gpm. Test gpm water capacity by running pump normally with hose and proper tip attached. Spray water into bucket for one minute and verify that you are pumping 2.4 gallons of water (or what ever gpm your machine is rated). Measure the amount of water that your machine delivered. If it delivered proper gpm and pressure is low then problem could be worn or improper tip. The pressure is created at the tip and pressure will drop as the tip wears. As the unloader/bypass wears, water will bypass at a lower pressure. (Try lowering the pressure regulator all the way ) If water measures less than rated delivery than the machine is bypassing water due to worn regulator/bypass, checkvalves pitted, oring in front of checkvalve worn or cut or missing, or body of pump where checkvalve/oring seat is pitted allowing water to leak past valve. The cap that is removed to access checkvalve must presses against checkvalve with enough force to prevent water from leaking thru oring and body of pump. Examine checkvalves and orings with maginfy lens and look for pitting. Valves surface and orings must be very smooth and tight fitting to work properly. Body of pump where checkvalve oring snuggs against must be very smooth. Any surface where oring seats must be smooth. As water bypasses it cuts metal and orings just like a leaking faucet so look for cuts in metal and rubber. This info and my experience is better suited for larger pumps and higher pressure but maybe it will help. Good luck with your repair.
Jul 11, 2010 | Karcher 2500 PSI Pressure Washer
I was topping off the oil level in my rx8 and a small peice of aluminum fiol from the oil jug fell in, will it hurt anything? about the size of your thumb nail.
It sure can.It is easily big enough and light enough to block oil pasages and starve parts of your engine for oil. It needs to come out. The chances are pretty good that it didn't fall too far in so start taking things apart where you added the oil but keep going until you find it. It might seem like a pain in the --- but so will a seized motor. Hope this helps.
Feb 28, 2010 | 2004 Mazda RX-8
I have pressure coming to my wand but when i attach the nozzel the water comes thru but with no force? I am trying to take the nozzel apart but can seem to do so. It is a Troy Built Washer and the wand is...
the red button is just for the warning label. Did you pull the nozzle down. This nozzle is an adjustable nozzle. You push it in and this is for the soap injector and you pull it out for the pressure. If you have done this, then you may need to replace the nozzle. You can even put a quick diconnect on the end and use the small tips you can buy local or replace with the same type nozzle.
Also check to see if there is something blocking the hole.
Jun 17, 2009 | Briggs & Stratton Garden
Carpet power head will not stay attached to telescoping wand
to answer your last statement, if you do not have a receipt, the warranty will go by the date ofyour serial number. the first 4 digits are the month and year. this model usually has a 1 year wty. the wand button may not be protruding as far due to dirt under the metal band. however you may still have an issue with the neck on the powerhead which will require shop service.
Jan 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Steam Wand Broken
Something is stuck inside the wand. Get a small pice of wire or small paperclip and inset and try to clear the blockage
Nov 12, 2007 | FrancisFrancis! X3 Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
108 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
