Question about Toshiba 50H81 50" Rear Projection Television
Toshiba 50H81 No picture and blinking red light. Have unplugged it, let it sit overnight and turned it back on wth no change. It is 5-6 years old and have never had any problems
    President:
  • 4,402 Answers
Most commom problem is convergance ic gone bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 08, 2008
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
How can I fix it
its definately a power supply issue. You may want to get a service manual for your model as it will have the info to trouble shoot the standby and start up voltages. You can get a manual emailed to you at the following link and they will help you trouble shoot the set. Heres the link.
http://servicemanuals.vstore.ca/
Jun 08, 2008 | Toshiba 50H81 50" Rear Projection...
Projection tv toshiba
my tv did the same thing except it is a 57in hdtv
May 21, 2008 | Toshiba 50H81 50" Rear Projection...
Tv won't come on
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the ned and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Open back cover, 9 screws and wirings (pls mark), removed(soldered) a electronic board infront of convergence ic. removed IC (stk392-110) (screwed and soldered).
Replaced everything and voila...! it is now working again..
no more shutsdown and red blinking light. Saves mo $400 for a repariman. of course just be careful with static and stuff.
Feb 29, 2008 | Toshiba 50H81 50" Rear Projection...
5 year old tv
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the net and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
I don't know how to solder, so I ask friend to do it for me. But I did the rest. Just to give you an idea that it can be done even if you don't know much about electronics. This in no way a recommendation but just stating my experience. Follow at own risk.
Feb 16, 2008 | Toshiba 50H81 50" Rear Projection...
Lite in the front of the TV when you turn on keeps blinking and no picture.
Q510, Ta1316 is your sync processor and probably the problem you're having here. It's a common one for this unit and you could pull the board and check the solder connections it has with the foil - - but you may need to replace it...
Nov 05, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Re Blinking Light...wont work
best advice is go get a manual book on how to fix tv
May 07, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 50h81 Red Blinking light
Apr 02, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
234 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
